HarryD's Avatar
Trunk Strut Repalcement
This weekend I decided to replace my trunk struts and retire my prop stick.
All in all, pretty uneventful, Interestingly enough was the modification to the lower attachment on the drivers side. I was expecting to find a clevis type pin that would be a pain to get the retainer off and the pin out. Instead, I found an M6 hex bolt that was screwed into place. I was able to take my 10 mm socket and unscrew it and remove.
For others who may need to do this job, this seems to a be a sensible replacement for the clevis pin at this location.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-16-2004, 01:04 AM
Jim Smolka's Avatar
Though some may dissagree, IMHO, the retainer piece is not needed on the lower pins. Well, one might need it one can pull more than 3 G's in a curve
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 02-16-2004, 02:37 AM
I agree you don't need a clip on the driver's bottom...
Did you ever compress ( by hand) even a *bad* shock ???
The force is enormous...and when the trunk is closed, even more so. That pin isn't going *anywhere*....I've run this way ( even track events) for 10 years with no problems...
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-17-2004, 09:35 AM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
I've been running w/o mine for a while as well. Great to hear I am not the only one!
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 02-17-2004, 09:59 AM
HarryD's Avatar
I agree that you don't really need the retainer clips.
All I was pointing out was that by having a threaded fastener in this location, it was mucho easy to remove as I was able to get a socket with an extension and universal joint on it and unscrew instead of trying to grip the pin in a tight space.
On my other three, I only have clips ont he top ones, and I think that it is mostly for appearance.
Harry
2020 MB E350 4Matic
Old 02-17-2004, 10:03 AM
Irrationally exuberant
ChrisBennet's Avatar
Of course if you know the trick, putting the clips on the bottom isn't hard...
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-17-2004, 10:17 AM
Senior Member
Jdub's Avatar
With new strut shocks, how did your trunk lid fit? Did you notice any raising of the lid over the fenders/front of windshield?
John
'78 Targa in Minerva Blue
Old 02-17-2004, 10:23 AM
HarryD's Avatar
John
John,
I was concerned about that but the trunk looked fine afterwards.
Harry
2020 MB E350 4Matic
Old 02-17-2004, 10:24 AM
mperkins's Avatar
Send a message via AIM to mperkins
where can i find these?? A quick search of the Pelican parts catalog and no luck! Mine are dead flat and I need replacements.
thanks!
Maurice Perkins
1980 SC Coupe
Old 02-23-2004, 09:58 AM
Randy Webb's Avatar
Hey - how are you clipless guys gonna win that Concours prize??
The difficulty of this job is nil compared to getting off a rusty starter barrel nut.
Old 02-23-2004, 10:36 AM
HarryD's Avatar
thanks!
They under "Miscellaneous". Try here: http://www.pelicanparts.com/catalog/shopcart/911E/POR_911E_miscel_pg5.htm#item24
Harry
2020 MB E350 4Matic
Old 02-23-2004, 10:59 AM
HarryD's Avatar
If that is all that keeps me from winning top honors in concours, it will be a very sad day indeed.
Harry
2020 MB E350 4Matic
Old 02-23-2004, 11:00 AM
