Formerly bb80sc
Vipergrün's Avatar
Hypothetical engine rebuild for a 3.0
Hello all...
Well, assuming that my motor will probably eventually need a rebuild and will (hopefully) be smog exempt in 6 years, I have thought about accruing parts for the big event.
So, here are my thoughts on some parts I'd like to gather;
964 cams (or more wild with carbs??)
PMO's /Webers
Higher compression pistons, perhaps Euro SC's??
I am sure there are tons of things I could do, open to suggestions. Since this isn't actually happening yet, I can spend all of the pretend cash I want
-b
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 02-21-2004, 09:18 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
If you are going to buy new P&Cs anyway, you might as well get the 98mm RSR P&C kit and make it a 3.2. I'm not sure but you might get away w/ S cams w/ those P&Cs and carbs.
If cost becomes a factor, there is also a 98m P&C kit that will work w/ CIS, then the 964 or 20/21 Cams would be perfect.
Wayne just had a big write up on the rebuilding forum on Short Stroke 3.2 building, go read through it to see what works and what doesn't.
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 02-21-2004, 09:28 PM
Here it is- Quick FAQ 3.0/3.2 upgrades to 3.2/3.4
'81 911SC Targa 3.6
Old 02-21-2004, 09:29 PM
Mark Wilson
Guest
Posts: n/a
Or go one step further - do the Max Moritz p's and c's with a 3.2 crank and it will be a 3.4. That's what rdane is doing right now.
Old 02-21-2004, 09:42 PM
Formerly bb80sc
Vipergrün's Avatar
....or maybe I stash aside a few hundred bucks month for a 3.6 upgrade The RSR stuff looks pretty trick..probably have to twin-plug, no??
-b
Cheers
-Brad
2015 Cayman GTS
Old 02-21-2004, 09:43 PM
Have no doubt, the type of engine you are talking about might cost the same as a 3.6 conversion, and you will have to spend even more to match the hp & torque of the 3.6.
The good side is that it wont be a used engine.
'81 911SC Targa 3.6
Old 02-21-2004, 09:53 PM
Now in 993 land ...
aigel's Avatar
bb:
Just save money and spend it when it is time. These engines live a very long time and your opinion about what to do (and the general trends and wisdom) may change until then. I would not stash parts for a project that's several years away, unless I get them now a hell of a lot cheaper (e.g. free) than later.
If you are hot for a rebuild, get a car that needs it. . You shouldn't have boutht an SC. I will leave it to the other SC guys to determine which model that would be...
George
81 SC (sold)
Old 02-22-2004, 01:16 AM
banjomike's Avatar
Look up the ongoing thread on low cost EFI for CIS motors. Once you Megasquirt it, then get some wilder cams, high compression pistons (unless the pistons are in need of replacement then go for the 3.2). Slap on some SSIs and no stock 3.2 will be able to keep up.
Of course George is right. By the time that the 3.0 is actually in need of a rebuild who knows what will be available...
Ultra light weight ceramic based pistons, cylinders, and cranks, bolt on self adjusting lifters, ceramic cylinder heads, super light weight valves. Composite intake stacks with custom EFI. 4.0 L 550hp at 11,000rpm in a motor that weighs 150lbs less and is as reliable as a stock 3.0L.
Of course by then all of the early Cayenne purists will be saying things like "Real Porsches have internal combustion engines" when complaining about the new Habanero. Anyway my point is it might be a bit of a wait. SPend the money on suspension in the mean time!
Mike
Searching for a new ride
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
http://www.pelicanparts.com/gallery/BanjoMike
Old 02-22-2004, 06:37 AM
rdane's Avatar
I have a very nice 3.4 that is about to be finished. If I were to do it again my take is there are three good answers. Prices go up as you read down the list.
1. Do a good valve job and add a high compression pistons if you can to your cylinders. If not I wouldn't worry about it. The most economical and reasonable choice in retrospect.
1. Do a new top end and add 98mm Max Moritz P&Cs to your CIS, 20/21 or 964 cams, SSIs and a good muffler (3.2 short stroke). 3.2 crank will add another 2K$+ to the project with CIS (3.4). Add an S cam, carbs or EFI and get another 30 to 40 HP. and a finicky engine. Either is the Porsche purist route.
2. Go shopping for a good deal on a 3.6. Then stick it away until I was ready for the transplant. You can do the other things that will be needed while you wait (oil cooling, suspension and brakes).
Costs for any of the three really depends on who is doing the work.
Old 02-22-2004, 10:02 AM
