Uno Dei Molti Porschisti
BarryJB's Avatar
Porsche Crest Engine lid - right side strut?
My 1985 coupe engine lid has a factory Carrera tail & a/c condenser. While I use double struts on the left side (I'm just about to put in 3rd set in 6 years), this lopsided boost in support always seems technically offensive!
I notice the firewall already has a mount for the front end of a RIGHT side strut - so I wonder... ...perhaps the 930 uses L & R struts for the whale tail...
Before I grab the calipers & reinvent the wheel, is there a factory R-side strut rear-(hinge-)end mount solution (e.g., adaptor bracket or 930 hinge), or source for a sketch to fabricate a suitable R-side bracket to attach to the hinge?
Also, the engine lid is reluctant to pop up on release without help, albeit new struts help some a while: Is a stronger catch push-up spring available, perhaps also related to the 930 whale tail?
Old 02-22-2004, 03:39 PM
rfuerst911sc's Avatar
I can partially answer your question,the turbos did have a hood shock on both sides and I had the same problem with my SC when I added a Carrera tail,the spring would not "pop" the hood open,I simply removed the factory spring and went to my local hardware store and matched up a stronger spring,cost me about $2.00 if I remember correctly and it pops open now no problem.
Old 02-22-2004, 03:56 PM
Who is John Galt?
Rondinone's Avatar
I had this lopsided problem also. Just today I finished my fix. I would take a picture but the sound padding is already glued into place.
I used a set of old 911 hinges off ebay, and swapped out the right side from my car with the left side from the pair I bought. Of course the left side has the shock mount. This causes a slight alignment problem, which is solved with a longer hinge bolt and the proper spacers. For the firewall, I built a bracket out of $1 worth of angle iron (the type with holes) that I bolted to the firewall. I passed bolts out from the interior by removing the rear panel behind the seats. The key is this: whatever you build, be sure that it's strong. The first bracket I built folded right up under the force of the shock. I'm still wondering about the effect of the longer hinge bolt, and I just might reinforce it too.
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 02-22-2004, 04:05 PM
Eric Coffey's Avatar
The 3.2L Carreras that came from the factory with the rear spoiler had the right side strut hinge as well. You might try calling used parts yards for one, or just fabricate a tab and bolt it on to your existing hinge.
Old 02-22-2004, 04:37 PM
BarryJB's Avatar
Thank you both, two questions, two posts and two solutions in about two minutes! Your posts together suggest the R-side yoke was added to the firewall of 911 bodies after the turbo was introduced... will definitely comply with suggestion to keep stuff beefy.
85 Carrera Coupe, OBD-I 993 3.6 conversion (bottomless list of mods)—425k+ miles. 100k on the 3.6, zero blue smoke, but oh the leaks... two broken 915s But G50 and all the other bits going in early 2024
Consolation & stealth vehicle: 05 Mercedes E55 AMG S211 "No one will suspect the Spa... silver station wagon".
Old 02-22-2004, 04:44 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
Welcome to this great board Barry.
FYI for guys w/ earlier cars, my '81 did not have a bracket on the firewall. I made my own and welded it in.
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 02-22-2004, 04:54 PM
Thr right hinge from a Turbo model has the bracket already attached.
Having a shock at both sides of the lid is the proper way to go. I've heard of "twist" and fitment problems on the left side when over-boosted with double shocks on that side.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-22-2004, 04:55 PM
BarryJB's Avatar
I just looked this up in the 911 Authenticity Series - it says only one pneumatic shock was used for all lids 1984 on, whether turbo, option 473 (Carrera) spoiler or none - so it's all a bit of a mystery, looking at Eric's photo of what definitely looks factory and my factory R-side firewall yoke. I'm with Will - both re turbo hinge (now my intended solution) and the gruesome hopalong lefty twist thing. Mr. Haab may have made a teensy error in his book, it seems.
Yes it is a great board, and it's good to be back, Ryan - I was a member a few years ago...
Thanks everyone - it's nailed! All I gotta do now is visit my wrecking yard and spin wrenches...
Old 02-22-2004, 05:25 PM
BarryJB's Avatar
Wil, sorry about rogue consonant I tacked on last post
Old 02-22-2004, 05:29 PM
RETIRED
Joe Bob's Avatar
Consider using a shock from a marine store for boat hatches....comes in stainless and is stronger and cheaper. I did, no more corrosion and never had to replace them since.
2012 ML350 3.0 Turbo Diesel
Old 02-22-2004, 05:33 PM
Rogue consonant ??? ....never noticed
---Wil Ferch
Wil Ferch
Old 02-22-2004, 05:50 PM
BarryJB's Avatar
Mike, including luggage bay, I've bought 6 pairs of struts in as many years... just got a $15 gift voucher from my boat store's frequent buyer (spender) club- since I don't have a boat (excluding Comanche trash truck) this is a great idea.
Old 02-22-2004, 06:41 PM
