Electrical question w/ project pics
Can someone please advise me on how & where I should connect the wires from two aux fans that I want to stay on continually when the ignition is on. These will be cooling a radiator on a v8 conversion project which started as a 1978 911SC. Due I connect to the fuse box or can I splice into the fuel pump wiring? PLEASE HELP
Also, thought I would include pics of the project, Thanx Vince
Old 06-16-2007, 03:19 PM
ANYBODY?
Old 06-17-2007, 05:01 AM
Gon fix it with me hammer
svandamme's Avatar
you have 2 threads on the same subject...
same answer here
do not plug in the fans directly into existing wires, you don't want to melt the wires by overloading anything
use a relay, and new fuse, then trigger that relay from anything that turns on with the contact, radio is a good source
Stijn Vandamme
BIMDIESELBMW116D2019
Old 06-17-2007, 05:16 AM
Wiring connections...
VBush,
Got a wiring diagram for my auxiliary cooler with fuse and relay. PM me with your FAX # and I'll send the wiring diagram.
Tony
Old 06-17-2007, 05:27 AM
never ending projects
niner11's Avatar
Looks like a pretty clean install. BTW, that garage rocks
Old 06-22-2007, 02:15 PM
vbush,
I too noticed the garage. GREAT garage. I also noticed your cooling fans. They look very thin. Do you know the name of the manufacturer/source? Maybe they make one appropriate for fender mounted Auxiliary oil coolers.
Rob Richardson
1974 911S
Carbed RS Clone engine
Turbo flares
2009 Carrera S - Porsche Racing Green, PDK
Old 06-22-2007, 06:10 PM
