Author of "101 Projects"
Wayne 962's Avatar
What Products are Missing from Pelican?
All of this talk about Island's 911 valve adjust gauge has got me thinking - what products do you wish Pelican carried that we don't carry?
Before you post indiscriminately, make sure that you do a search in the search engine above to make sure that we don't already carry it.
I'll have Eugene (my new catalog manager for Porsche & BMW) take a look at this thread...
Thanks!
Wayne
Old 02-23-2004, 11:46 AM
TerryBPP's Avatar
POR-15, 3M Bonding adhesive (for SC flare mounting), Lexan windows, Roll cages (bolt-in), Big bore cylinder kits (2.7-2.9, 3.6-3.8), Cams.
Old 02-23-2004, 11:58 AM
Certified Pre-Owned
BGCarrera32's Avatar
-Kit-like packages for 915 transmission rebuilds (and others)
-Alternative besides factory or repro fuel tanks for Carrera 84-89 years
-Accurate numbers and complete illustrated catalog section for Dansk or other exhaust systems (besides B&B crap)
Otherwise...pretty darn nice site...!
'84 Carrera Coupe
Old 02-23-2004, 12:04 PM
TerryBPP's Avatar
Oh, a complete hose replacement set for CIS.
Old 02-23-2004, 12:06 PM
carmaneddy's Avatar
Seats--their are a variety of nice period repro's and some sport seats would be nice. I am looking for a correct style sport seat for my 1972.
Old 02-23-2004, 12:08 PM
vash's Avatar
kinda petty, but the hardest thing for me to find was the "silicone grease" mentioned in so many of the BBS tech articles. i never did find the dowcorning version. maybe add this to the rest of your line of lubes, etc.?
i ordered the fuel sender gasket, and got the cork one. only the factory rubber unit will fit my car, and some other's. maybe offer both with different part numbers?
poof! gone
Old 02-23-2004, 12:14 PM
drag racing the short bus
dd74's Avatar
1) Triad mufflers
2) Lexan windows
3) TRE aluminum motor mounts
The Triad muffler - I've said it once, I'll say it again. This is hands-down better than any other mufflers you offer, and much less expensive. Plus, you don't have to cut the valance to fit a dual-out version.
Lexan windows - do you offer those?
TRE makes some very nice aluminum engine mounts. Pure craftsmanship. Next Mulholland run, I'll let you take a look-see.
I searched out Lexan and found nothing, you already carry some "other brand" motor mounts. And Triad is not there at all.
The Terror of Tiny Town
Old 02-23-2004, 12:15 PM
Detached Member
Hugh R's Avatar
The 1000 mm fan belts for use with the Seiko A/C compressors, and a note on the web site that the one that you sell is for the cars with the original A/C compressor (I ordered the wrong one, and at the price, its probably not worth sending back. Also, when I ordered the oil hoses, it didn't say that they come with the nuts and ferrels included and so I ordered them as well, Again, for the price I won't bother to send them back.
Hugh
Old 02-23-2004, 12:19 PM
I'll second the Lexan windows and add....the ones with the correct RS leather strap. Velco may provide more flexibility and be cheaper, but that RS strap looks really cool.
"Rust never sleeps"
Old 02-23-2004, 12:20 PM
joecrum's Avatar
Replacement seatbelts (the original type).
joe
>82 3.0 SC
>01 Audi S4 Avant
Old 02-23-2004, 12:23 PM
Air Conditioning parts, barrier hoses. Modern fuse blocks to replace the old style.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 02-23-2004, 12:25 PM
I'll second that. I think putting together a few kits for the different versions of CIS will add alot of value. I don't mind cutting hoses to fit but I don't have a clue what to order to replace mine & I'm definitely not going to pull them all of, measure, order new quantities & then try & remember where they all go when they arrive!
Old 02-23-2004, 12:28 PM
Senior Member
Doug Zielke's Avatar
Complete D-I-Y EFI conversion kits for CIS equipped Porsches.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 02-23-2004, 12:30 PM
Britain Smith's Avatar
I would like to see the roller bearings as a replacement option for the front a-arm suspension bushings?
Also, I would like to see the small misc seals and gromments to replace the ones going through the firewall, doors, front truck area, etc.
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine
'74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans.
'80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks
-- www.britainracing.com --
Old 02-23-2004, 12:31 PM
I would also like to see the WEVO product line...they have some awesome stuff.
-Britain
Old 02-23-2004, 12:32 PM
Carl Bauer's Avatar
Long style rear seat retension straps for 911's. The longest ones you have 5.25 inches are not long enough for my 911SC.
Carl Bauer - 1979 RoW 911SC - Orange Bar Products
Only because I'm dealing with this problem right now, but where are the 915 drain/fill plugs that aren't of the recessed hex type?
Jordan
'83 911SC
Old 02-23-2004, 12:33 PM
i want one of those...
Rufblackbird's Avatar
Location: formerly a grass shack in Hawaii, now Peoria, AZ
I agree with the lexan goodies...
how about bolt on hairdryer kits?
Jeff
'72 911 T Targa widebody VTK #111385 http://www.911vtk.com
Old 02-23-2004, 12:38 PM
s_wilwerding's Avatar
Maintenance items for Boxsters. Air filters, oil filters, etc.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 02-23-2004, 12:42 PM
Certified Pre-Owned
ditto there...that happened to me too...the cork WILL NOT fit under the sender...the part # from the PET cd is the correct rubber part...the oil sender and fuel sender gaskets are not interchangeable...
Also, rebuild kits from Denso AC compressors...
'84 Carrera Coupe
Old 02-23-2004, 12:48 PM
