-   -   8X16 Part# vs Dimensions Confusion - HELP! (http://forums.pelicanparts.com/porsche-911-technical-forum/150418-8x16-part-vs-dimensions-confusion-help.html)
Wavey 02-25-2004 05:57 AM
OK, before I get flamed for not doing my homework, be assured I've tried!
I'm trying to buy a pair of 8X16 Fuchs (911 fitment). The wheels have 2 different part numbers:
911 361 020 45
911 362 117 00
The seller says, and the pictures confirm, that the wheels appear to be identical. He has measured the backspacing and confirmed that they match - both have 122mm backspacing. Front spacing is also the same, and the petals appear to match visually.
Here's the problem: I've found conflicting information in the reference material I have, and neither agree with the actual wheel measurements.
This link: http://members.rennlist.com/911pcars/WheelWts.html
indicates that both numbers have 112mm backspacing, which doesn't match our measurements.
This link: http://members.rennlist.com/1976c38/index.html
indicates that the first number has a 120mm backspace, which is close enough to our measurement, but doesn't list the second number.
I'm satisfied that the pair of wheels in question have matching backspacing, will fit my Carrera, and appear to be the same visually. I believe one is an "early" wheel and one is a "late" wheel. But in that case I expected them to have different backspacing and to look different.
My question is, what is the difference between these 2 part numbers, if any?
palle7688 02-25-2004 09:07 AM
Fuchs PN: 911 362 117 00, is 8*16, 10,6 mm offset for 911.
Fuchs PN: 911 361 020 45 does not exist acc. to Bruce Andersons perf. handbook.
The closes I can get is 911 361 020 42 which's 8*15, 10,6 offset.
There no PN with 45 in the end.
All with 361 are "15 except 911 361 016 10 which are "14.
All with 362 are "16.
All with 020 are "15.
Are you sure both are "16, maybe 42 is misread as 45, in that case both will have the same 10,6 mm offset.
After written this I ran a check in PET, this is what came up:
911 361 020 45 Forged wheel 8J*16, 10,6 mm offset, dropped please use as replacement:
911 362 117 00 wheel-cast allumin. alloy, 8J*16, 10,6 mm offset.
I didn't know there where a cast fuchs wheel, I thought all where forged.
Apperently P. had Fuchs wheels made forged uptill '84 and cast after '84???????????????????????
Hopes this helps.
Any real experts out there?
Palle
speeder 02-25-2004 10:02 AM
Yes, PET refers to forged Fuchs as "cast" in some instances, don't ask me why. There were never any non-forged Fuchs 5-spoke 911 wheels.
It sounds like they are both the same wheel, If they are identical I wouldn't worry about it. :cool:
KTL 02-25-2004 11:15 AM
Dave,
The wheels are indeed the same dimensionally as far as offsets and width are concerned. But aesthetically/appearance-wise they are different.
My buddy Mark has a full set of .361 wheels in 7's and 8's, so i've personally seen the difference. I've also seen the difference in .361 and .362 16x6 wheels. I posted it here:
http://forums.pelicanparts.com/porsche-911-technical-forum/95993-16x6-fuchs-variations.html
So as you can see, the difference is in the shape of the "petals" on the face and a few other details. I'm sure this could translate into actual strength differences and not just appearance, but I know nothing about stress analysis nor metallurgy.
don911 02-25-2004 11:28 AM
Kevin,
What differences did you see on 8x16 wheels? I've looked at the pixs of the 6x16 wheels and I'm not seeing those differences in the pedals on 8x16s. I have one 8x16 of each part number and if you can specify where the differences are on an 8x16 wheel, I can check out my wheels.
KTL 02-25-2004 12:02 PM
Here may be one of those weird Porsche issues.
Because .361 16x6 and 16x7 wheels definitely appear different than their .362 counterparts. I've seen it.
But Don says .361 and .362 16x8's look the same? WTF? Only wheel I haven't seen side by side is the 16x8. :confused:
Wavey 02-25-2004 12:18 PM
Thanks, Palle - the PET info you found goes a long way toward clarifying things, other than the obvious error Porsche made with the "cast" wording.
Kevin, I checked that link a few weeks ago, and I can see the difference in those wheels. Thanks very much for posting that, BTW. But these wheels, with 2 different p/ns, look exactly the same:
http://forums.pelicanparts.com/uploa...1077743789.jpg
I wonder if, after production was begun on the substitute number, visual changes were made mid-production, but the number wasn't changed? Or maybe the differences were never there on 16X8s?
don911 02-25-2004 12:23 PM
I'll look at them again and take some measurements of the pedals. I took some pixs of the profile and didn't see a difference. If there are differences, the way they are painted may make it harder to see. I'll post some pixs tonight.
KTL 02-25-2004 01:24 PM
Dave,
Your picture would make me think those are .362 wheels with the "sharper" looking petals. But as you said, they are .361's!
Sorry to add to the confusion fellas. Probably was a wild assumption on my part. :(
don911 02-25-2004 01:30 PM
Kevin, the picture above is one of each p/n. 911 361 020 45 and p/n 911 362 117.
KTL 02-25-2004 01:34 PM
Duh. Of course. That's the whole point of this topic.
I'm an idiot. A free "slap upside Kevin's head" coupon is awarded to everyone in this topic..............
Wavey 02-25-2004 01:58 PM
If only my arms were longer...
So, anyway, now you see the dilema. I'm starting to think that the wheels must be identical, no matter what the part number. I'm not trying to be anal about it, just don't want to end up with 2 mismatched wheels (been down that road before).
However, another issue is that the actual measurements from these wheels don't match the charts we're all refering to.
Kevin, I'll PM you later - got a meeting right now.
don911 02-25-2004 04:46 PM
I think I found the differences. Not the outcome I wanted but better to know now.
The pedal side of each wheel seem to be pretty much the same. I measured some things on each wheel and all were the same. At least as near as I can tell with the black paint and measuring to a curve.
I say pretty much because there are differences.
1. The valve stem hole has a bevel on one wheel (362) and is a straight hole on the other wheel (361).
2. Where the spokes meet the hole for the center cap. The 361 wheel has a sharper curve at the interface than the 362. Visually it's hard to see but you can tell when you run your finger into the curve.
The difference on the inside of the wheel is in the shape or profile of the wheel looking in line with it. Hard to describe but easy to see. The shape from about the center to the inside lip is different. (in the pix, the inside of the wheel is the left side)
Mounted on a car you wouldn't be able to see the differences in the two wheels but they're there.
http://forums.pelicanparts.com/uploa...1077759754.jpg
http://forums.pelicanparts.com/uploa...1077759789.jpg
http://forums.pelicanparts.com/uploa...1077759824.jpg
http://forums.pelicanparts.com/uploa...1077759851.jpg
http://forums.pelicanparts.com/uploa...1077759873.jpg
tholyoak 02-25-2004 05:09 PM
My take on the subject is that prior to 1985 the 8x16 wheel had a part number of 911 361 020 45, in 1985 that part was discontinued and the new part was 911 362 117 00, which as shown above has very slight differences visually but is dimensionally (width as offset) the same.
There are also 2 other 8x16 wheels that you can come across according to the Porsche parts book
Pre-85 911 361 020 99
Post-85 911 362 117 90
which are the unpainted versions of the previous two wheels (which are the black star versions) from the factory that I guess could then be painted any colour you wish.
Todd
Bill Verburg 02-25-2004 07:30 PM
Wavey, At my page http://members.rennlist.com/1976c38/index.html
the factory o/s #s are dead on, but since the factory never published the front or backspace #s I collected as many as I could from generous Pelicans and put them in one place . The #s you see there are the average of the #s that have been reported to me. The more data I get the more accurate those #s will become. Measure yours when you get them and it will be added to the pot.
FYI, all of the +10.6mm o/s fuchs will fit the same but there are minor differences that are mostly cosmetic.
Include part #s, weights, cosmetic differences that you notice and tires that fit and I will add that info as well.
tchanson 02-25-2004 07:49 PM
Another example:
Factory painted 8x16, 911.362.117:
http://forums.pelicanparts.com/uploa...1077770689.jpg
http://forums.pelicanparts.com/uploa...1077770723.jpg
Tim
speeder 02-25-2004 08:29 PM
Tim, That's a pretty wheel.
nostatic 02-25-2004 08:45 PM
I know that when I was looking at wheels, I found some 8s that didn't match the part number that had been given here (can't remember which one). I had Jeremy at TRE check, and at some point the part number changed (was superceded in the PET). So identical 16x8 wheels can have 2 different part numbers.
Wavey 03-01-2004 02:51 PM
Bill-
Thanks for the addition of the diagram to your page! Looks like your dimensions are correct as compared with the other link. When I actually get my hands on some wheels, I'll send you my dimensioons too!
jpahemi 04-26-2005 08:47 PM
Tim:
What's the colour code for your wheel?
Thanks,
J.P.
fastpat 04-26-2005 09:04 PM
Re: 8X16 Part# vs Dimensions Confusion - HELP!
911 361 020 45
911 362 117 00
I was at the local dealer's parts counter today with the same question and part numbers for 16x8 wheels. They showed me the computer display that had both above part numbers, and when inputing 911 361 020 45 it said that the current number to order is 911 362 117 00. The parts book considers them identical.:D $944.00 each, if I order them, with my PCA discount plus tax.:rolleyes:
tchanson 04-26-2005 09:36 PM
Originally posted by jpahemi
Tim:
Thanks,
J.P.
980/S7, Silver Metallic.
Tim
jpahemi 04-27-2005 03:02 AM
Tim:
Porsche colour, right?
Thanks,
J.P.
KTL 04-27-2005 05:26 AM
Re: Re: 8X16 Part# vs Dimensions Confusion - HELP!
Pat,
There's a difference between the 361 wheels and the later superceding 362 wheels. I've compared 16x6, 16x7 wheels and found some differences in shape of the petals, dimensions, etc. I imagine the Fuchs company improved on their forgings over the years and thus had to update the part numbers for Porsche? Just a guess on my part.
As far as the price you got? Shop around. I've seen dealers that can knock a good chunk of change (more than $100) off the price you were quoted. And that was for a 16x9 911 362 119 00 wheel. But as Bill Verburg keeps saying, Fuchs prices like these make wheels like Kinesis, Fikse, etc. look more and more like the way to go! Especially since 17 in. tires are more readily available in the size, brand one may desire.
tchanson 04-27-2005 06:57 AM
Tim:
Thanks,
J.P.
JP,
Right. Factory painted centers, factory paint code.
Tim
thabaer 04-27-2005 07:25 AM
I was speculating to myself that there could be differences in brake clearance on the inside, your pics of the centers seems to suggest that may be true. Prime opportunity to feed Bill's wheel database!
island911 04-27-2005 08:07 AM
cool
Don & KTL, excellent posts and photos! (I love this kind of stuff)
I recently digitized a 7" (for a CAD model) So, I certainly was getting into thte sublties of the design/shape.
FWIW, the later seem to have gotten a bit more sophisticated, using C2 curvature (rather than the simpler C1 - simple round) on the end of the spoke. (if that means anything to anyone)
I imagine that subtle change helps the tooling last a bit longer, as well as simply giving a better shape.
Coo-stuff - Thanks.
KTL 04-27-2005 10:27 AM
Ha!
We get a guy with some metallurgy background and things really get interesting!
Thanks Glenn. My "improved on their forgings" comment was simply a wild assumption. :p But I figured there had to be a reason for them to change the shape of the wheels in so many ways.
Bill Verburg 04-27-2005 12:38 PM
Bill-Thanks for the addition of the diagram to your page! Looks like your dimensions are correct as compared with the other link. When I actually get my hands on some wheels, I'll send you my dimensioons too!
My data is only as good as you guys measure, always glad to have more. Pluses are weights and caliper clearance #s
Wil Ferch 04-27-2005 03:37 PM
I found the same thing that Bill did in that some of the backspace numbers don't jibe.....it sometimes comes down to whether ( or not) the thickness of the rim forging itself is taken into account as part of the backspace measurement.....or if its taken from some imaginary "seating surface" the tire rides-on within the rim.
I've posted similar data as Bill's on the Rennlist web site with posted credits from *where* the info came from too. It may even be reposted within this BBS.
Wil
