Water Leaks
Hi I have a 82SC and I am having a problem with the car leaking water into the cabin and the carpets getting soaked. I have replaced the door seals and check that the fresh air intake is not full of leaves. Where else could it be coming from ? Is it possibly the windscreen seal ?
Old 02-26-2004, 02:39 AM
Glasgow 911SC's Avatar
Front and rear windows, door could be missing the moisture lining, sunroof. There are a few areas. Best to strip as much carpeting out as possible and give it a good soaking while someone sits inside looking for the tell tale drips.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 02-26-2004, 03:42 AM
Did you get the memo?
onewhippedpuppy's Avatar
Don't let it go, galvanized SCs are rust resistant, not rust proof.
‘07 Mazda RX8-8
Old 02-26-2004, 03:55 AM
Not Quite Banned
Thomas Owen's Avatar
Use a garden hose and isolate areas of the car while someone sits inside. Try working up so that you end with the sunroof. Good luck-
Thomas Owen
1972 911T
1972 911S
Old 02-26-2004, 04:06 AM
