backfiring, hard to start
What causes a car to backfire. Im having trouble with starting my car and it will backfire. The neighbors have surendered but arn't offering any help. When I do get the car started and warmed up it seems to run fine.
I have a 2.4 with webers and a electomotive ingintion. Any ideas on where I should start?
2000 Boxster S (gone) 1972 911s Targa (sold) 1971 911t coupe roller (sold) 1973 911t coupe / 3.2 (sold) Gruppe B #057 |
Weber backfire is usually due to a lean mixture. Or your timing could be way off.
What do your main and idle jets look like? Tom. |
I'll check. Also my fuel pump is very noisy. I wonder if I'm getting enough pressure. Im supposed to be getting another fuel pump from unclezak but it must be lost in the mail, its been a month and a half.
I just bought the car and I havn't been able to drive it. Ive been painting and there is no windshield installed. Its always been hard to start, but once started seems to run and idle fine. I havn't looked at a jet since my motorcycle days in the early 70's. What am I looking for? Blockage?
Unoffended by naked girls
Backfiring through the carbs or exhaust? If it's through the carbs, it's too lean. Pull the idle jets and make sure they aren't plugged. Do you have a float gauge? (I do). If it runs better when it's warm. I've got an appt at 2 tomorrow, but I could shoot over early....
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
19 years and 17k posts...
My backfiring was caused by bad plug wires and plugs that were gapped too wide. I have a CIS system, so it's quite a bit different, but the cold start problem and backfiring sound familiar. As soon as I regapped the plugs and replaced the plug wires, no more problems... my neighbors don't miss the backfires!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Thanks dhoward, Ill give you a call tommorow or you can call me. 636 899 1635.
Thanks, Mark
