Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
CRAP!!! More alternator woes...little help please...
So, today I decided to tackle the alternator conversion. I'm switching from an external reg. to an internal. While I was at it, I cleaned and scraped the fan housing and fan, and painted them.
Upon reassembly, it turns out that the thrubolts that attach the fan housing and the rear air guide aren't LONG enough to get any bite. Check the pics:
The new alternator is Bosch part # AL9341X. The motor is a 79 3.0 SC.
What part number *should* I have gotten, or what am I supposed to do now?
Thanks.
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 03-01-2004, 01:09 PM
Rennch on YouTube
rennch's Avatar
I should clarify...it's NOT the thrubolts, it's the alternator housing itself that is a 1/2" longer, and thus the thrubolts lose 1/2".
Can I just go try to find longer ones? Or won't that work?
Michael O'Neal -
Old 03-01-2004, 01:10 PM
304065's Avatar
Uhh, I'm not the kind of guy who says I told you so, but on 2/18. ..
It requires a different fan shroud, like a 930. . .4R or 7R or something like that, I don't remember (although I will look on my shroud and tell you this weekend if you want).
You could do like I did, spend three hours grinding down the back of the housing to give the bolts room to fit, or you could bite the bullet and score a later shroud, like a 930. . . 5R or something like that, out of a Carrera, that has the proper depth.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-01-2004, 01:21 PM
304065's Avatar
I found the old thread from when this happened to ME in the archives, . ..
The absence of a voltage regulator made me suspect this possibility, so, I had ordered a NEW Valeo internally regulated alternator from the 84-89 Carrera, expecting to drop it in. Except that it's too thick, by about 3/4"-- and when the fan is mounted, the blades protrude about that distance from the edge of the fan shroud-- a safety issue to say nothing of making the belt fit.
'81 R65
Old 03-01-2004, 01:24 PM
Rennch on YouTube
rennch's Avatar
I thought you were referring to the air guide on the back, which I had the replacement for.
I wonder if I could take it to a machine shop to grind?
Michael O'Neal -
Old 03-01-2004, 01:25 PM
Check also the fan nut...may be a 16mm x1 pitch vs later 17.5mm x 1.5 pitch or somesuch...theres a difference there too on some models.
Thought you might want to check this out before you got *too* far..
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-01-2004, 01:34 PM
Rennch on YouTube
rennch's Avatar
Yea...the new alternator came with it's own new nut.
I'm going to get the Bosch 400X, which should fit. It will be here tomorrow.
Michael O'Neal -
Old 03-01-2004, 01:41 PM
echrisconnor's Avatar
Michael,
I'm new to this latest thread of discussion so I may not have all the facts. Be careful about modding the fan shroud. I can see from your pictures that the two alternators are different and may also have different offsets for the fan. I've heard of people dropping in the wrong alternator and then not having their fan and crank pulley line up.
By the way, I saw you blasting down 28th on Saturday morning. My wife said to me "nice paint job!" Looking good!
Chris
'76 911 Carrera 3.0
Old 03-01-2004, 01:58 PM
Rennch on YouTube
rennch's Avatar
Blasting, eh???
It was too damn early to be blasting, from what I recall. I had played at the Foundry Friday night, and was taking my date home.
I have ordered the right part, and hopefully they'll deliver it to me tomorrow.
Michael O'Neal -
Old 03-01-2004, 02:04 PM
