-   -   What is the estimated HP gain using K&N cone filter and adapter intake on 3.2L? (http://forums.pelicanparts.com/porsche-911-technical-forum/150820-what-estimated-hp-gain-using-k-n-cone-filter-adapter-intake-3-2l.html)
movin 02-27-2004 01:22 PM
I wondered if the K&N cone filter and adapter intake will add any noticeable HP gain in a stock 3.2L. If it does make a difference does it occur at the higher RPM's and how much?
Bill Verburg 02-27-2004 01:31 PM
-2
Rot 911 02-27-2004 01:32 PM
It has to be Friday.
ChrisBennet 02-27-2004 01:35 PM
-3 hp is what I've seen.
-Chris
movin 02-27-2004 01:36 PM
That's what I thought, but doesn't Steve Wong make allowances for such modifications when 'chipping'?
HarryD 02-27-2004 01:37 PM
Is it with an e-ram or without?
No E-ram --> -2
With E-ram --> -20
:D
BGCarrera32 02-27-2004 01:39 PM
Extrude honing and overbored throttle bodies yes, air filters probably not...
movin 02-27-2004 01:44 PM
The intake (lead-in) to the mass airflow box has a cast aluminum transition that adapts the cone filter to the box. The shape resembles an intake port, large 3" dia. opening transitioning to the retangular opening of the airflow box. It would seem that the adapter would promote better airflow than the stock box. Is that the case?
einreb 02-27-2004 02:03 PM
Are the cone filter/adapers sold on pelican? I searched and didn't see them. I suppose the posts claiming that they let in dirt scare me a bit... regardless of the hp, I really like how it cleans up the engine bay.
-bernie
Jeff Alton 02-27-2004 02:22 PM
zero, zilch, nadda, none, ...........
Jeff
Steve W 02-27-2004 02:24 PM
Depends on the level of hp your engine produces. At 220 hp, probably nil, over 250-260 hp, Bruce Anderson said they cut open the airbox cover and gained about 5 hp at the top end. That said I am guilty of a cone filter with my air flow sensor. My engine probably produces around 250hp and my tests were limited to comparing a grossly mismatched cone filter and cheap $5 adapter from Autozone, and another that was a well matched aluminum adapter with filter I heavily modified and reshaped internally like a big mouth velocity stack. The difference in air fuel ratio was such that the matched filter setup required about 1-1.5% more fuel to maintain the same afr. It is negligible and not something I usually account for in chips, as the variation in flow characteristic from one Carrera engine to the next is much greater than that. Cool air and if you use a cone filter, a properly shaped/matched adapter are most important to max power.
greglepore 02-27-2004 05:56 PM
FWIW, why do it if you're not going to get the filter out under the grill where the cool fresh air is? It's easy if you're creative with some pvc.
88 Club Sport 02-27-2004 06:36 PM
Not sure I can argue with what everyone says about power but it sure does make for a clean engine compartment. Check out my 3.2 with a/c and stock box vs. the non air, k&N.
http://forums.pelicanparts.com/uploa...1077935623.jpg http://forums.pelicanparts.com/uploa...1077935636.jpg
Bill Verburg 02-27-2004 06:46 PM
As has been mentioned the final nail is that the K&N pulls air from the rear(hottest) part of the engine compartment.:(
john walker's workshop 02-27-2004 07:02 PM
hold a K&N filter up to the light, and think about how much dirt would go thru it as you travelled along a dirt road.
movin 02-27-2004 10:11 PM
Wait a minute, the adapter I'm talking about makes a right angle turn towards the rear, exposing the filter to the incomming air going to engine fan. That should make a difference compaired to the one shown in the previous response, lower temp. Only problem is the filter gets wet when it rains or the car is washed.
Mikkel 02-28-2004 12:55 AM
Pretty much like the stock airbox. (My filter extends to the same position as the airbox intake)
Mikkel 02-28-2004 01:04 AM
At one time mine did. Not good I tell you :rolleyes: :o
beepbeep 02-28-2004 02:32 AM
Nothing. It lets more dirt into engine though.
Bill Verburg 02-28-2004 05:03 AM
Huh? Every stock air box I have ever seen pulls air at the front. If the cover is modified then it can also pull from the rear.
Something akin to this
http://forums.pelicanparts.com/uploa...1066078289.jpg
