What is the estimated HP gain using K&N cone filter and adapter intake on 3.2L?
I wondered if the K&N cone filter and adapter intake will add any noticeable HP gain in a stock 3.2L. If it does make a difference does it occur at the higher RPM's and how much?
Old 02-27-2004, 01:22 PM
Bill Verburg's Avatar
Bill Verburg
Old 02-27-2004, 01:31 PM
Friend of Warren
It has to be Friday.
Kurt V
Old 02-27-2004, 01:32 PM
Irrationally exuberant
ChrisBennet's Avatar
-3 hp is what I've seen.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-27-2004, 01:35 PM
That's what I thought, but doesn't Steve Wong make allowances for such modifications when 'chipping'?
Old 02-27-2004, 01:36 PM
HarryD's Avatar
Is it with an e-ram or without?
No E-ram --> -2
With E-ram --> -20
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-27-2004, 01:37 PM
Certified Pre-Owned
BGCarrera32's Avatar
Extrude honing and overbored throttle bodies yes, air filters probably not...
'84 Carrera Coupe
Old 02-27-2004, 01:39 PM
The intake (lead-in) to the mass airflow box has a cast aluminum transition that adapts the cone filter to the box. The shape resembles an intake port, large 3" dia. opening transitioning to the retangular opening of the airflow box. It would seem that the adapter would promote better airflow than the stock box. Is that the case?
Old 02-27-2004, 01:44 PM
Are the cone filter/adapers sold on pelican? I searched and didn't see them. I suppose the posts claiming that they let in dirt scare me a bit... regardless of the hp, I really like how it cleans up the engine bay.
-bernie
Old 02-27-2004, 02:03 PM
Jeff Alton's Avatar
zero, zilch, nadda, none, ...........
Jeff
www.turn3autosport.com
Old 02-27-2004, 02:22 PM
Steve W's Avatar
Depends on the level of hp your engine produces. At 220 hp, probably nil, over 250-260 hp, Bruce Anderson said they cut open the airbox cover and gained about 5 hp at the top end. That said I am guilty of a cone filter with my air flow sensor. My engine probably produces around 250hp and my tests were limited to comparing a grossly mismatched cone filter and cheap $5 adapter from Autozone, and another that was a well matched aluminum adapter with filter I heavily modified and reshaped internally like a big mouth velocity stack. The difference in air fuel ratio was such that the matched filter setup required about 1-1.5% more fuel to maintain the same afr. It is negligible and not something I usually account for in chips, as the variation in flow characteristic from one Carrera engine to the next is much greater than that. Cool air and if you use a cone filter, a properly shaped/matched adapter are most important to max power.
Old 02-27-2004, 02:24 PM
greglepore's Avatar
FWIW, why do it if you're not going to get the filter out under the grill where the cool fresh air is? It's easy if you're creative with some pvc.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 02-27-2004, 05:56 PM
Not sure I can argue with what everyone says about power but it sure does make for a clean engine compartment. Check out my 3.2 with a/c and stock box vs. the non air, k&N.
'02 6GT2 - Weekend toy
'04 6GT3 - Track weapon
'13 Cayenne GTS - Daily duty
'77 Yamaha RD 400 - Wheelie machine
Old 02-27-2004, 06:36 PM
As has been mentioned the final nail is that the K&N pulls air from the rear(hottest) part of the engine compartment.
Bill Verburg
Old 02-27-2004, 06:46 PM
hold a K&N filter up to the light, and think about how much dirt would go thru it as you travelled along a dirt road.
206 637 4071
Old 02-27-2004, 07:02 PM
Wait a minute, the adapter I'm talking about makes a right angle turn towards the rear, exposing the filter to the incomming air going to engine fan. That should make a difference compaired to the one shown in the previous response, lower temp. Only problem is the filter gets wet when it rains or the car is washed.
Old 02-27-2004, 10:11 PM
Mikkel
Guest
Posts: n/a
Pretty much like the stock airbox. (My filter extends to the same position as the airbox intake)
Old 02-28-2004, 12:55 AM
Mikkel
Guest
Posts: n/a
At one time mine did. Not good I tell you
Old 02-28-2004, 01:04 AM
beepbeep's Avatar
Nothing. It lets more dirt into engine though.
Thank you for your time,
Old 02-28-2004, 02:32 AM
Huh? Every stock air box I have ever seen pulls air at the front. If the cover is modified then it can also pull from the rear.
Something akin to this
Bill Verburg
Old 02-28-2004, 05:03 AM
