Glasgow 911SC's Avatar
Quick Pedal Cluster Rebuild Question
I was going to rebuild my pedal cluster this weekend. i've removed the floorboards following Wayne's book. I'm now at the disconnect clutch cable part.
Now I have to remove the retainer pin. That's the pin to the left of the green dot below, yes? Does it just hammer out? Wont budge at the moment.
Next I'll have to unscrew the clevis from the cable. Thats' at the red dot, yes? I can only access this with the clutch pedal pressed. Is this correct or am I gonna launch something when the thing unscrews?
Thanks for any info.
Chris
1982 911 SC Hellblau Metalic
1997 Boxster 986 2.5l
Old 02-28-2004, 08:32 AM
disconnect the clutch cable at the trans first. then unclip the front clip and maybe it comes out with a bit of screwdriver twisting, and maybe it's stuck. they get notched by rubbing on the lever, or rusted, and occasionally i just have to pry the clevis apart, ie: break it, in order to separate it from the lever. i keep a supply of clevises for that reason.
206 637 4071
Old 02-28-2004, 09:00 AM
Thanks JW. I was thinking that removal at the tranny end would be the case but quietly hoping I wouldn't have to crawl under my car in the freezing cold. Maybe I should leave this and replace the cable and clevis etc at the same time.
Chris
Old 02-28-2004, 09:27 AM
Binge User
Schrup's Avatar
I had to bust my clevis fork to get the retainer pin out because of what John described. I used a long skinny punch to get it started, then pryed on it with a screwdriver till it broke. The retainer pin had worn a 1/8 inch groove in the clutch shaft arm. I used a dremel to clean up the hole in the arm & pressed in the new brass bushing.
Paul
Old 02-28-2004, 09:40 AM
Not Quite Banned
Thomas Owen's Avatar
Glas - you see the clip to the left of the red dot? You have to pivot that down...that is the retainer for the pin. Now with the cable loose to pin will come out.
Good luck-
Thomas Owen
1972 911T
1972 911S
Old 02-28-2004, 10:47 AM
Thomas,
Here's a pic of that type of retaining clip:
Sherwood
Old 02-28-2004, 12:00 PM
vash's Avatar
yes, look at the pic of the part. you unclip it at the back and rotate it abit. then grab it with some needle nose pliers and pull towards you. i would disconnect at the tranny first.
poof! gone
Old 02-28-2004, 04:47 PM
BTW, no need to remove the clevis. It's part of the clutch cable. It'll just fall away from the pedal assy. clutch arm after you remove the retaining clip. You also have to remove the ball socket for the throttle cable (above the clutch clevis).
Sherwood
Old 02-28-2004, 05:07 PM
That makes more sense seeing that pic Sherwood. I had it pivoted down but didn't want to force it too much. Maybe I'll just go ahead with the removal afterall. I got the accelerator linkage disconnected easily enough. hopefully I shall have squeak free pedals soon.
Chris
Old 02-29-2004, 04:41 AM
I take it in Wayne's book when it says
'The pedal cluster and the master cylider are bolted together on the early cars, so you need to disconnect the master cylinder in order to remove the pedal cluster.......after removing the belly pan'
it includes my car as an early car??? It really is too cold to be under my car at the moment.
Chris
Old 02-29-2004, 12:24 PM
Yep, the two bolts on other side of the push rod into the brake master cylinder must be loosened and removed. It gets worse though: not only do you have to remove the splash guard under the front axle assembly you also need a second person to hold the wrench on the other side; some people get around this by welding the bolt head to the pedal cluster bracket. Cheers, Jim
Old 02-29-2004, 12:34 PM
Doh. Thanks Jim. I really do think I'm going to leave this for the better weather then.
Chris
Old 02-29-2004, 12:43 PM
Early_S_Man's Avatar
Porsche Crest
No, Chris ... your car has power-assisted brakes, so the master cylinder is in the front 'boot' ...
No need to remove anything but the pushrod up to booster ... assuming that you DO want to remove pedal cluster!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-29-2004, 02:04 PM
hehe. am going round in circles on this one. Thanks Warren.
Chris
Old 02-29-2004, 03:27 PM
Warren is right about the MC for your car being in the luggage compartment. However, looking at the parts diagrams for the power assisted brake system I cannot tell if one still has to get underneath to remove the nuts that secure the pedal cluster bracket or if these are now welded to the floor pan and one can simply loosen the screws from above. You'll know soon enough if the screws do not loosen from above. Cheers, Jim
Old 02-29-2004, 05:04 PM
Senior Member
ohecht's Avatar
I just did this on my 82, and there are two bols under the steering rack guard that you need to take off from underneath the car. Mine were on studs welded to the cluster, so there was no need to have anyone hold them on the other side.
The clutch pin slide out easily for me, I had more problems with the brake actuating rod and the zinc plated bracket.
Olivier
Olivier Hecht
1982 911SC
Old 02-29-2004, 05:38 PM
