-   -   Stone guards R/R (http://forums.pelicanparts.com/porsche-911-technical-forum/151503-stone-guards-r-r.html)
Larry Harris 03-02-2004 04:27 PM
Stone guards R/R
In removing stone guards off a turbo body should I use a hair dryer to soften up the old adhesive, gently pull off the old stone guards , clean the surface of old adhesive and then add the replacements....or is there a more complicated way to do it?
Larry
goat 03-02-2004 04:36 PM
That way should work fine. You might want to have on hand some product like goo-gone to remove any gummy residue as well. but looks like you got that covered by the clean up process.
VincentVega 03-02-2004 06:05 PM
Have at it. I found a hard plastic scaper helped get mine off. In my case heat helped a little, but not much. The bug & tar stuff did the trick.
fly944 03-02-2004 06:22 PM
IRON
ACTUALLY,
I have found that if you can add steam it really helps. If you have a good iron, place a towel on the stone guards and steam them, they should after a few minutes peel right off.
aigel 03-02-2004 10:39 PM
Don't use goo gone for the remnants. Use 3M adhesive remover and try it in an invisible location, just in case.
