Larry Harris's Avatar
Lightbulb Stone guards R/R
In removing stone guards off a turbo body should I use a hair dryer to soften up the old adhesive, gently pull off the old stone guards , clean the surface of old adhesive and then add the replacements....or is there a more complicated way to do it?
Larry
2001 Turbo
Old 03-02-2004, 04:27 PM
goat's Avatar
That way should work fine. You might want to have on hand some product like goo-gone to remove any gummy residue as well. but looks like you got that covered by the clean up process.
Tim.
1988 911 Carrera. Silver.
1973 914 Metalic Blue.
2012 Cayenne S
Old 03-02-2004, 04:36 PM
VincentVega's Avatar
Have at it. I found a hard plastic scaper helped get mine off. In my case heat helped a little, but not much. The bug & tar stuff did the trick.
Old 03-02-2004, 06:05 PM
Send a message via ICQ to fly944
IRON
ACTUALLY,
I have found that if you can add steam it really helps. If you have a good iron, place a towel on the stone guards and steam them, they should after a few minutes peel right off.
Old 03-02-2004, 06:22 PM
Now in 993 land ...
aigel's Avatar
Don't use goo gone for the remnants. Use 3M adhesive remover and try it in an invisible location, just in case.
81 SC (sold)
Old 03-02-2004, 10:39 PM
