Gordo2's Avatar
Help, Spark Plug Socket Stuck On #6
Quick help please, before I decide to give up for the night and drown myself in alcohol. It's stuck on the plug, not wedged in wierd or anything.
Re-removing the new plug is an option but very painful. For some reason it would spin by hand about a half turn and then require the socket wrench at 2 clicks a pop (i.e. about 20 min to get the plug in).
Gordo
Sign me up for the dumb A$$ award. As I was moving through the other plugs I was thinking, man it would blow if my plug socket got stuck down there. Meanwhile in my toolbox I have a 8" extension with a locking ball (for another vehicle, too long for the Porsche). But I was thinking it would be nice to have a 6" one for the 911. Napa (where I bought the locking extension) is just down the street, but no... Toooo lazy.
Kick me while I'm down.
By the way, if Napa makes a 6" locking extension I'm all over it. If you haven't seen one check on it, they are slick.
Don "Gordo" Gordon
'83 911SC Targa
Old 03-03-2004, 07:29 PM
I'm off the hook.....
Man, I sure hope it's not cross threaded.
No, I don't sing. Based there for too long.
Old 03-03-2004, 07:30 PM
Pop the valve cover off--just be careful with the gasket?
'73 CIS T with a 3.2 on a stand in the corner
Old 03-03-2004, 07:31 PM
vash's Avatar
two, 3" locking extensions from sears! i lost #6 too. that was before i found this bbs. i almost cried. wierd, dont buy one 6", too long. but on my car i stick one 3 in and then lock the other 3 onto it. cake.
cliff
poof! gone
Old 03-03-2004, 07:32 PM
don911's Avatar
It doesn't sound like you have the factory socket wrench. If you don't have one, pick one up when you have a chance. It makes plug changes less of a PITA.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Gordo2's Avatar
Guess I'm Off To Sears
Thanks Unfixed,
Was hoping to wrap it up tonight, sounds like it's alcohol for me.
P.S. Need some angry drinker smilies.
Don "Gordo" Gordon
'83 911SC Targa
Old 03-03-2004, 07:38 PM
Gordo2's Avatar
Got It
I loosened it and found I was able to unscrew it with my fingers without any binding. The old one was painful coming out, this one was painful going in, but it came out by finger. I did put a little anti-sieze on the threads of the new one prior to installation.
By the way, I do have the factory wrench. Just found out. I always wondered what was in that black bag in the trunk. Slick tool, wish I would have used it for the other 5...
Thanks folks,
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 03-03-2004, 07:59 PM
vash's Avatar
as i understand, do not use antiseize on the plugs. you dont need to tighten that much anyways.
poof! gone
Old 03-03-2004, 08:02 PM
Oh man, what a relief!
Now it's time for the alcohol.
Old 03-03-2004, 08:06 PM
Zeke's Avatar
A trace of antisieze doesn't hurt from the consensus that I have noticed. The only thing too much antisieze does is apparently keep the plug from grounding properly. This again from a couple year's reading here.
IMO, that can be corrected by making sure the plug seat, crush washer and head seat stay clean.
Old 03-03-2004, 08:15 PM
poorsha's Avatar
Invest $5 in one of these from BERU.
It is flexible and makes plug installation a snap.
Old 03-03-2004, 08:29 PM
Gordo2's Avatar
Beru
Poorsha,
What is that thing, can't tell from the pic (looks like an ugly stick)? Where do you purchase it? I'm always up for new tools (except when I'm too lazy to drive to the store or look in my trunk).
BTW are you the same Poorsha that was in DC a while back?
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 03-03-2004, 08:58 PM
poorsha's Avatar
Gordo.
No DC for me.
Too cold for me.
The tool is a very simple spark plug installation tool.
The plug is pushed into one end and you simply turn it into the motor.
Saved my bacon many times.
You should be able to get it at any place that sells Beru plugs.
If you can't find it just let me know and I will get one for you.
78 911SC sunroof Coupe (SOLD)
97 328i Convertible
Old 03-03-2004, 09:23 PM
Gordo,
A 6" piece of rubber gas line or vac. line works well also. Stick the plug into one end (make it a tight fit), slide it into the tunnel and rotate it slowly. This method also prevents you from cross threading the head because the hose will slip on the plug before the plug can cut the threads.
I welded a 3" ext. to a plug socket (with rubber insert, a must). I know I got a tool kit with the car 20 yrs ago, but I must have put it away somewhere for safe keeping, or my wife cleaned up the 2nd floor of my garage one day, trying to make more room for her junk and it is now lost forever.
Terry
Terry Hastings
Baltimore, MD
1972 911T
LTHSURVEY@AOL.com
Old 03-04-2004, 05:22 AM
Double Trouble
targa911S's Avatar
I use a piece of rubber hose stuck over the top of the plug to get it started, you have better "feel". Once it is there I set the first locking 3" then the second after that. A walk in the park.
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 03-04-2004, 06:14 AM
Don't think I have ever tried the tool kit plug wrench but I will next time. When I use a socket with rubber insert I use duct tape to attach socket to extension. Works fine.
Old 03-04-2004, 09:03 AM
bigchillcar's Avatar
for mine, i just wrapped masking tape around the plug and extension to keep them together for the job...
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 03-04-2004, 09:09 AM
pwd72s's Avatar
Hazet makes a cute plug wrench...adjustable length. Not cheap tho... here's a link:
http://www.samstagsales.com/images/hz2505-2.jpg
another way to go is a sears locking 3" extension, hooked to a 13/16" swiveling plug socket...the swivel on the socket makes for the proper length, the locking extension makes for no sockets lost down the hole. Also, snap on makes a 4" extension, allowing the use of a standard 13/16" spark plug socket. Lot of ways to do this job, evidently....
Old 03-04-2004, 09:17 AM
Senior Member
This discussion is similar to one on the earlyS board a couple of weeks ago. The Craftsman set up with the 4" locking extension and the swivel plug socket from Sears is about perfect for the 911.
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 03-04-2004, 09:49 AM
