Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
Quick question on setting timing...
I have seen numerous posts here for timing suggestions, at least for my SC...and it usually goes something along the lines of 5deg BTDC at 1K-RPM no more than 35deg BTDC at 6K-RPM.
my question is this...why even worry about the idle timing? Just set the timiming at 35Deg at 6K then adjust the idle down to 950K...am I being too simplistic here? Why even check at 1K?
as usual, any comments are greatly appreciated.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 03-05-2004, 07:50 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
Nope, not being too simplistic IFF you know that your vacuum and mechanical advance are working correctly.....setting total advance at 35BTDC then bringing idle back down is fine.
If you initially set to factory specs of 5BTDC and then check total advance, it should advance to ~28-30BTDC @6K. Also, the timing should advance in some sort of smooth linear fashion, not instant. If you are not getting 28-30 degrees @6K, your mechanical or vacuum advance may be faulty. So, if you then set timing to 35, the idle/low rpm timing will be too advanced causing low rpm detonation under load. What if the advance were to 'unstick' at high rpm's...then you'd be way too advanced up high causing possible detonation etc....
Not a bad idea to check both idle and total advance to make sure you have the 'total curve'.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 03-05-2004, 11:13 AM
Black and Blue
Kemo's Avatar
ok...thanks...that clears that up! BTW..i love the if-and only-if... LOL
Kemo
Old 03-05-2004, 11:18 AM
kstylianos's Avatar
LOL...yeah, you got to throw that in sometimes......
Charlie Stylianos
1982 SC Targa
Old 03-05-2004, 11:29 AM
