Question Air Pump? (Pls. Don't Flame)
Guys,
I have a 78 SC and am still new to these engines. Now, when looking at the engine, on the right side is what I believe is called the air pump. What is that for? I believe I have seen Euo cars with out them.
Someone please explain their purpose.
Thanks,
JCC
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!---
-2001 996 Turbo
Old 03-06-2004, 01:02 PM
SilverPoly's Avatar
The right side is the air conditioning unit.
The smog pump is on the left side (driver's side) of the engine. The smog/air pump helps to cool the exhaust before it gets to the cat. The pump at most uses 1 hp to operate.
Old 03-06-2004, 01:13 PM
RETIRED
Joe Bob's Avatar
Yeah....actually it's a compressor. If there is the rest of a/c in the car....you can try and get it running....but the old style refrigerant is NOT cheap. The old hoses leak.....
Best to rip it out, strat over or deal with the heat....
2012 ML350 3.0 Turbo Diesel
Old 03-06-2004, 01:16 PM
The smog pump injects more normal (unburned) air into the exhaust streem to promote further burning off combustion products. It was on engines long before catalytic converters so cooling the converter is not likely to be the reason for the pumps' existence.
Old 03-06-2004, 03:44 PM
RETIRED
Joe Bob's Avatar
An air pump injects air into the heads and reduces Hydrocarbons. The same can be done by disconnecting one injector on an FI engine.....watch the HC levels go WAY down. Ask me how I know....
%^B
Old 03-06-2004, 03:47 PM
Par911's Avatar
It's purpose is to be removed, for weight savings of course. Since you have a '78 check with your local emissions place, if they have the rule for 25+ years and you are exempt then get rid of it. I did !!
Old 03-06-2004, 06:32 PM
