Need (P201) engine adapter dimensions..please
I need dimension 'a' in the section diagram below. Dimensions 'b' and 'c' wouldn't hurt either. Also, what is the diameter of the curved tube steel?
http://forums.pelicanparts.com/uploa...1078705752.jpg http://forums.pelicanparts.com/uploa...1078705733.jpg |
Get one in hand and you'll see it would be lot of work to duplicate. Even with free material and a machine shop at your disposal you would have a hard time justifying it. I encourage you to look at one in person so you'll know what you are up against at least.
-Chris |
No worries, not trying to duplicate it.
Dimension please...anyone? |
a = 4 3/4"
b = 1 1/2" c = 6 1/4" diameter = 2.35" (59.8mm) In case it will help, the distance from the engine mounting surface to the inside of the yoke is 6" http://forums.pelicanparts.com/uploa...1078754128.jpg -Chris |
Thanks for taking the time to help me out, Chris!
So, dimension 'a' is only 4-3/4"...huh. I would've guessed from the pic it would be greater. That would make the thickness of the semi-circular adapter ring itself 1-1/4" thick (based on the 6" dimension you gave). Wow. Oh, when I mentioned the "diameter of the curved steel tubes", I meant the curved ones, not the straight tube that connects to the jack stand. I should have labeled that better. I've updated my drawing. http://forums.pelicanparts.com/uploa...1078760494.jpg |
Sorry, I didn't read closely enough the first time. Yes, the adapter ring is 1 1/4" thick. Hold on sec, I'll go out to the garage and measure...
OK, the curves pipes are .95"/24.1mm in diameter. -Chris |
Great! Thanks again for the info.
I'll update when I actually put the info to use. Geez, I was supposed to be done with this project back in Dec. '03, but have been sidetracked by an ongoing illness. EDIT: I posted an U P D A T E to this thread here: http://forums.pelicanparts.com/porsche-911-technical-forum/158501-unorthodox-engine-yoke.html?highlight=yoke |
| All times are GMT -8. The time now is 03:26 AM. |
