traderdan's Avatar
Send a message via Yahoo to traderdan
1972 911t No Electrical Power .... Need Help!
Just brought a '72 911 back to life went to do some check measure adjusts on it. Had an assistant start it up to keep it running. Starter cranked a couple times then the whole car's electrics went dead nothing no lights nada. I had the batter tested and it's fine and has a full charge. Any suggestions?
'80 Mazda RX7
'73 Karmann Ghia
'68 Karmann Ghia
'73 MGB
'59 Singer Gazelle
'69 Opel GT
'77 911 Slant Conv.
'72 911 T
'72 Dodge Charger /w 318 (need parts)
Trader Dan
www.tdvideogames.com
Old 03-08-2004, 06:30 PM
dfw911's Avatar
The ground? Maybe something came loose when the engine turned over.
Bart
'72 targa 2.7
Old 03-08-2004, 06:40 PM
3.2 CAB's Avatar
Check the ground attaching points, battery, trans. etc. Make sure all are clean and tight.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-08-2004, 08:04 PM
Dan,
It sounds like the excitement is just beginning for you! Like others have suggested, check your grounds. Eventually, you'll probably want to spend a day or two cleaning ALL the contacts on the car, including battery, ignition, lights, wipers, gages, fuse block etc. Get a set of good wire brushes, a couple of beers, and have fun. You'll be amazed at how much corrosion you'll find once you get started. You can double check the connections with a wiring diagram and an ohm meter.
-Jim
Old 03-08-2004, 08:48 PM
traderdan's Avatar
ok thats kinda what I thoght too it's just a shame to get so far and then have electrical gremlins peek up. I guess since the entire car lost electrical power I'll start at the ground straps to the battery and transmission first clean or replace all fuses etc etc. I'll have my work cut out for me tomorrow it seems
'80 Mazda RX7
'73 Karmann Ghia
'68 Karmann Ghia
'73 MGB
'59 Singer Gazelle
'69 Opel GT
'77 911 Slant Conv.
'72 911 T
Trader Dan
Old 03-08-2004, 10:50 PM
Aussie's Avatar
Same happened to me once with my 911T and it ended up being a crack in the fuse holder
1969 911 T (SOLD), 1977 911SC (SOLD), 1999 BMW M3 (SOLD), Current Car 2005 Lotus Exige
Old 03-08-2004, 11:17 PM
traderdan's Avatar
I'll check the fuse holder too that might explain a lot - this 911t has been setting in a junkyard for about 20 years I'm suprised it even ran when I unsiezed it etc. Now I know what Porsche owners mean when they use the term "bulletproof".
'80 Mazda RX7
'73 Karmann Ghia
'68 Karmann Ghia
'73 MGB
'59 Singer Gazelle
'69 Opel GT
'77 911 Slant Conv.
'72 911 T
Trader Dan
Old 03-09-2004, 12:12 AM
