Gon fix it with me hammer
did my carrera tensioner upgrade today..
and realize that i was very , very lucky left tensioner device, next to the hydraulic one right one , before replacement seems like some DIY self made thing aluminum block, with a nut in it to tension the chain sprocket arm ( if that's the correct name for it) the left one was not tense the right one was i thank myself for having been paranoid last fall it could have been bad. has anyone seen this sort of tensioner before???
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Those are the racing style mechanical units. From what I understand they are the safest type of tensioner however they require periodic adjusting . You were in no danger with these. The mechanical adjusters will even bring you $50.00+ in good used condition. A new set is $200.00 .
Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
That type on mechanical tensioner, or ones very much like it, have been used since the 70's. They work well on race engines that are torn down on a regular basis but not as ideal on
street engines. They can contribute to chain stretch if they are too tight. You will probably be fine with your new hydraulics, it's not easy to measure chain stretch with the chain in the engine. On high mile engines when I've discovered those tensioners, I've gone ahead and replaced the chains just for peace of mind.
Bruce Herrmann 97 C4S '04 330i '08 Cayenne S '07 4.8 X-5 |
so not complete bad work...
i still consider myself lucky not to have pushed the car much the left one did have considerable flex.. i could move the chain up and down quite a lot with that tensioner in place after dropping in the hydraulic one, and releasing the pin.. the movement was gone... very tense ![]() thanks for your answers.. another thing learned !
Well you learn something new every day!!!
Those are quite amazing! So when one adjusts those is there a way to measure the slack in the chain, i.e. what is the spec one would tighten those to? Cheers Jakes
If you want to run with the big dogs, you can't pee like a puppy!!! 92 Rover Metro 1.1 (54 manly horsepower) - Dont knock it it does 60 mpg!!! 81sc / 3.2 litre transplant (Broken BIG Time ) SCWDP deserter - HP junkie wannabe |
I ran a set of those in the 70s. Before Porsche made reliable tensioners, those were very popular, especially with racers. The tough part was setting the chain tension and checking it every 10-12K miles.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
The left one is an old tensioner that has been gutted and bolt with a large nut has been substituted. The right one is a machined piece of aluminum. It was a regular product sold as a substitute for a chain tensioner. I remember the triangular shape. It was probably sold by PP or Automotion when they were still in business.
I have converted adjusters in my 70'. Adjustment: You take the slack out of the chain and tighten the screw maybe 1/2 turn more. That's what I remember. You didn't want the chain to rattle and you didn't want it to be too tight. David Duffield Last edited by Oldporsche; 03-14-2004 at 01:59 PM.. |
well, it was a big surprise to find them!
but i'l stick to hydraulic ones now.. don't want to drop my engine every 3 months, eventhough i probably will not do 10k miles a year... piece of mind
