Granger heat motor
Hello: I just finished the install of my Granger heater motor and it just don't seem to spool up has hard as the old Porsche heater motor, I am judging it right at the heater fan on a 77 911s. Am I doing something wrong, could it be the wires are on wrong. I think I went red to power and black to the other wire????????
Thanx Chris from Ohio
Raise hell and run naked!!!!!!
Old 02-14-2004, 03:19 PM
david914's Avatar
Not sure if it means anything, but I did the Grainger motor install this past Fall. On my car there was almost no noticeable increase in air from before the motor install. Since my factory motor was shot when I bought the car, I don't have anything to compare it to. The factory motor must turn at a higher RPM than the Grainger motor as I can't imagine the factory going through the trouble of installing all of that extra hardware just to gain a mere whisper more air.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 02-14-2004, 07:27 PM
Senior Member
ohecht's Avatar
I saw in another post that the motor will spin either way based on the wiring, and that person found that red on motor to brown on the car gave the proper rotation.
I am about to do this fix myself, and you may have the fan rotating in the wrong direction. Based on the design of the cage, it would not move any air at all spinning backwards.
Olivier
Olivier Hecht
1982 911SC
Old 03-11-2004, 04:19 PM
Send a message via AIM to fintstone
Yes..Oliver is correct...simple DC motors run backwards when you reverse polarity..so you need to be careful when you install any fan motor...especially a nonfactory replacement...be it the footwell blowers, carrera oil cooler fan, A/C condensor or evaporator fans, or the engine heater blower. If the fan is turning the wrong direction it will actually cause the motor/fan to fight the air flow from the shroud reducing both the air flow and the life of the new fan motor.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 03-11-2004, 11:13 PM
Senior Member
ohecht's Avatar
Am I the only one that had to replace the through-bolts on the motor to make this work? I ground the plate as thin as I could, but I only had about 2mm of threads showing on the motor bolts, so I had to replace them to get enough to mount it to the factory plate.
Olivier
Olivier Hecht
1982 911SC
Old 03-12-2004, 04:01 AM
Wavey's Avatar
Thanks for pointing this out - I just corrected this on the original post!
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 03-14-2004, 10:06 AM
3.2 CAB's Avatar
Dfink had a really good post on this matter. Tells of red to brown and black to yellow power wire to get the blower to function correctly. Hopefully this is the correct thread: skillet to heater blower
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-14-2004, 10:24 AM
v9ff's Avatar
Do these Grainger motors work better than the factory ones? When mine broke, I got a used motor for $50 and it dropped right in with no hassle.
Old 03-14-2004, 10:41 AM
No, just a lot cheaper than a new one and cheaper than most used ones.
Old 03-14-2004, 10:52 AM
Wavey's Avatar
And more durable. The OEM motors are fragile and lightweight.
Old 03-14-2004, 11:24 AM
I took the advice about the wiring, went up to the hanger over the week end and changed the wires and the granger motor, works great. Also the motor running backwards will put out a little air but nothing like it running the right way.
After I hooked the motor up right I went for a little drive to test. There is an area when I am coming home about 7 miles long I run her pretty hard, well during that run I finished off the Throw-out bearing that has been wining since I bought the 911s 77. Now today I plan on pulling the motor and doing the clucth, pressure plate, bearings, 1st gear syncro, oil cooler seals, etc. I was hoping to get this year out of her so I can finish my plane I have been building for 8 years. To many projects going!!!!!!!!!!!
Chris from Ohio
Old 03-15-2004, 05:51 AM
I am hoping my engine or tranny let go to, but no luck. Guess I have to find that road where I can push it a little further.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-15-2004, 07:55 AM
