-   -   What's causing this "thunk"? (http://forums.pelicanparts.com/porsche-911-technical-forum/153596-whats-causing-thunk.html)
techweenie 03-15-2004 09:33 AM
I have a 'thunk' when turning moderate to hard corners. It's coming from the rear of the car. (72T MFI Sporto)
It doesn't sound quite like a broken sway bar mount -- which is the typical cause of such sounds -- and it's further ruled out by the fact there's no rear sway bar(!)
I can feel the thunk in the chassis, so it's not just a shock dust cover or anything insubstantial. It's as if there was something weighing several pounds sliding across inside the engine compartment -- but I can't see anything that would work that way. I'm selling the car and want any issues taken care of.
Suggestions?
yelcab1 03-15-2004 10:19 AM
CV joints?
avendlerdp 03-15-2004 10:24 AM
My 70t does the same thing. I think it's spring plate bushings. I'm switching to neatrix anyway so I'll soon find out. Anyone??
Alex
thabaer 03-15-2004 02:40 PM
shock bushings can feel snug to the touch but have enough slack to thunk under driving loads.
dfw911 03-15-2004 03:51 PM
Is it a repetitive noise or does it just "Thunk" once in each turn
avendlerdp 03-15-2004 07:00 PM
One thunk per turn. Only on hard turns.
H.G.P. 03-15-2004 07:13 PM
How does one go about diagnosing? Is the slack evident upon basic inspection?
Also, will this symptom occur repetitively, per each wheel cycle, while driving?
techweenie 03-15-2004 11:01 PM
I'm going to have to codify the thunk with some careful observation over the next couple of days.
Thanks for all the input!
IROC 03-16-2004 04:40 AM
I had a thunk like this once and after searching forever it turned out to be one of my shocks was toast. It was a Koni red shock and it had almost no resistance to movement when I removed it (and it was only about a year old - Koni obviously replaced it for free).
Something to check.
Mike
