What's causing this "thunk"?
I have a 'thunk' when turning moderate to hard corners. It's coming from the rear of the car. (72T MFI Sporto)
It doesn't sound quite like a broken sway bar mount -- which is the typical cause of such sounds -- and it's further ruled out by the fact there's no rear sway bar(!) I can feel the thunk in the chassis, so it's not just a shock dust cover or anything insubstantial. It's as if there was something weighing several pounds sliding across inside the engine compartment -- but I can't see anything that would work that way. I'm selling the car and want any issues taken care of. Suggestions?
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
CV joints?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
My 70t does the same thing. I think it's spring plate bushings. I'm switching to neatrix anyway so I'll soon find out. Anyone??
Alex
1972 Porsche 914 Project 2000 BMW M5 1973 Aermacchi 350 |
shock bushings can feel snug to the touch but have enough slack to thunk under driving loads.
Is it a repetitive noise or does it just "Thunk" once in each turn
Bart '72 targa 2.7 |
One thunk per turn. Only on hard turns.
Also, will this symptom occur repetitively, per each wheel cycle, while driving?
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
I'm going to have to codify the thunk with some careful observation over the next couple of days.
Thanks for all the input!
I had a thunk like this once and after searching forever it turned out to be one of my shocks was toast. It was a Koni red shock and it had almost no resistance to movement when I removed it (and it was only about a year old - Koni obviously replaced it for free).
Something to check. Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
