126coupe's Avatar
Technical Bulletin
Check your lay shafts! the first photo is a rejected lay shaft, its tough from the photos but a substancial ridge. most likely from a non bearing case.
The 2nd photo is from my 8000 rpm engine failure. the rod hit the oil pump so hard it locked and twisted the splined end of the shaft!
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 03-17-2004, 08:46 PM
