Limbo
Slider79SC's Avatar
Gear identification
Can anyone help me identify a couple of gears?
I have a stock 4th and a stock 5th and the only numbers I could find on the gears were:
2348
9223
Does this help identify anything? Which one is which?
My car is a 79sc.
Thanks for the help.
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 03-17-2004, 09:59 PM
Slider,
I am uncertain if you are looking for gear ratios, or attempting to decode those 4 digit numbers. We can shed some light on the gearing itself.
If you indeed have a factory stock 915 gearbox in your SC, 4th gear ratio is 26/26 yielding a final drive ratio of 1.000 to 1. Your 5th gear ratio is 28/23, which yields a final drive of 0.821.
Hope this helps.
Ed LoPresti
RacePro Engineering
New York
Old 03-17-2004, 10:20 PM
Limbo
Slider79SC's Avatar
Thanks for the response Ed,
I am trying to figure out which gear is which because I want to put the stock 5th back in my transmission. I have a fully active gear box now and 5th is killing me on the higway because it is almost 1:1 and I am tired of running that many RPM's going down the road.
Thanks again.....
Old 03-18-2004, 05:45 AM
Limbo
Slider79SC's Avatar
I am attempting to decode those 4 digit numbers on the gears.
Old 03-18-2004, 07:32 AM
Geary's Avatar
Count the teeth. Your stock 5th gear pair has 28 teeth and 23 teeth respectively.
Old 03-18-2004, 07:39 AM
the scribed 4 digit numbers are just matching numbers for the gear set.
206 637 4071
Old 03-18-2004, 07:50 AM
Slider,
The four digit numbers are serial numbers only and should be numbered in pairs.
5th gear pair is the gear pair with the smallest of the two spline configurations. This will allow you to ID any 5th gear set, regardless of ratio.
Regards
Hayden
Old 03-18-2004, 07:53 AM
Limbo
Slider79SC's Avatar
Thanks Geary and John,
John, are the gears marked with a part number anywhere?
no part number.
206 637 4071
Old 03-18-2004, 09:45 AM
