Question Lower rear shock bolts
Ok, this all started with a broken head stud and oh look, I can see the top of the rear shock nuts, now that the engine is out. Guess I had better replace them. Although, I have to admit that the original Boges, even with only 17K miles, are pretty soggy compared to the new Bilsteins.
I noticed that the lower rear shock bolts have a red substance on the threads. Given the effort required to remove these, I assume that it's red Loctite. Should this be used again on reinstallation or should I just clean up the threads and reinstall dry?
John
Old 03-18-2004, 10:10 AM
I think you're looking at a red paint mark from the factory which likely indicates the fastening was "complete" or the proper amount of bolt rotation ( indicating torque) was applied....not loctite
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-18-2004, 10:51 AM
No, it's not the red paint mark on the bolt head. It's reddish-pink stuff on the actual threaded part of the bolt. It was fairly tough stuff to wire brush off.
John
Old 03-18-2004, 10:55 AM
Friend of Warren
I don't use loctite. Actually I use antisieze on the threads to make sure I can get the bolts out later. Those steel bolts going into aluminum threads can almost guarantee that they will lock tight all on their own.
Kurt V
Old 03-18-2004, 10:56 AM
Pat S's Avatar
I did the same as Kurt with antisieze.
Current: 07 S4 Avant, 06 Volvo S60R
Sold: '74 911, 01 986, 93 Volvo 240
Old 03-18-2004, 11:00 AM
Thanks guys.
John
Old 03-18-2004, 12:17 PM
Zeke's Avatar
Loctite does not retain it's color when cured.
Old 03-18-2004, 02:10 PM
I believe you screw the bolt into a captured steel threaded insert that is in the aluminum banana arm. I don't believe Loctite was used...but may have it from the actions of a previous owner?
---Wil Ferch
Wil Ferch
Old 03-19-2004, 09:53 AM
---Wil Ferch
I doubt it with that kind of mileage and the fact that these are the orginal shocks, but you never know! Maybe the factory was using some wierd tinted antiseize paste.
John
Old 03-19-2004, 10:43 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Most of the antiseize that i've seen Porsche use is the copper stuff.
The lower shock bolts are typically stubborn. I agree that Loctite was probably not used, but you never know. I know the factory didn't use it because my microfiche repair manual states the torque specs and any antiseize or threadlocker needed for any fasteners. No Loctite that I can remember mentioned in my fiche.
Kevin L
'86 Carrera "Larry"
Old 03-19-2004, 10:55 AM
Use antisieze and torque to spec (95lbs?). Those bolts are so long that red or even blue loctite would make it very hard to loosen.
Old 03-19-2004, 01:04 PM
