sc sc is offline
sc's Avatar
930 rotors w/ big silver-fvd caliper adapter needs washers?
I have just installed late model 930 rotors with 993 front calipers on my 79 sc using FVD adapters. the adapter fits the strut, but the adapter needs about 3/8" in washers to clear the rotor.
Is this normal to use washers with this setup, it just doesn't look right?
Old 03-22-2004, 02:22 PM
Bill Verburg's Avatar
The 1 piece '82-89 versions?
Bill Verburg
Old 03-22-2004, 02:39 PM
sc sc is offline
sc's Avatar
Yes- 930 rotors from a 86 turbo. Any clues?
Old 03-22-2004, 04:20 PM
What hubs?
Bill Verburg
Old 03-22-2004, 04:30 PM
sc sc is offline
sc's Avatar
I'm using 930 hubs as well. The calipers are dead center on the centerline of the rotors, but without the washers the caliper makes contact with the rotor.
Old 03-22-2004, 04:51 PM
If I understand you, it is fine to use some spacers to center the caliper on the rotor
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 03-22-2004, 06:20 PM
A washer yes, but 3/8" seems to be a lot. Have you contacted FVD? The 993 front caliper has the same o/s as a Big Red neither uses more than a thin washer when used w/ 2 piece rotors and the correct flat hat. ANY caliper o/s is supposed to be in the caliper adaptor
This is what a correct installation should look like. I suspect that the issue is related to the use of the 930 rotors and hubs on the SC. When those kits are sold for the '80 on 930 they use a different caliper adaptor than when they are sold for SC or '78-79 930
Bill Verburg
Old 03-22-2004, 08:20 PM
sc sc is offline
sc's Avatar
Its not the adapter to strut in question, that fits fine. Its the adapter to caliper that needs the washers.
Old 03-22-2004, 10:02 PM
Are you sure it's a 993 caliper and not a 993tt Big Red? The difference is in the height of the caliper. The Big Red is ~10mm taller and needs a larger rotor. The 993 can be used w/ the 930 304mm rotor the Big Red cannot, it is usually used w/ a 322mm rotor.
Bill Verburg
Old 03-22-2004, 10:11 PM
sc sc is offline
sc's Avatar
Its a 993 caliper. The person I bought them from put big reds on to replace these.
Old 03-22-2004, 10:29 PM
You have the wrong adapter if you need washers between the caliper and the adapter.
Bill Verburg
Old 03-23-2004, 02:24 PM
sc sc is offline
sc's Avatar
Thanks Bill. Thats what I thought. I don't think they do much work on early cars, this is the second set of wrong adapters. The first set I ordered for a 911 with big black calipers and they were also did not fit correctly. FVD stated that if I were using 930 rotors I needed a 930 adapter. I thought all 911/930 adapters were the same, since if you were using a radial mount caliper and a 32mm rotor the only other factor is which hub will be used. If you look at Vehicle crafts adapters it is only one type and part number.
Old 03-23-2004, 03:51 PM
