930 Distributor Rotors - What's the difference?
Does anyone know the difference between the early (76-79) 930 distributor rotors and the late (86-89) ones? They all seem to use the same cap. But the early rotor is $24 instead of $6!
There's no listing of a part for the 80-85 cars on PP...
From the catalog:
Ignition Rotor - 911 Turbo (1986-89) H-602-902-00 $5.95
Ignition Rotor - 911 Turbo (1976-79) H-602-901-01 $23.25
Confused,
Colin
Old 03-25-2004, 10:12 AM
Is it the rev limiter ? My 79 930 Rotor has a centrifical rev limiter. Were the later ones electronic ?
Dave
Old 03-25-2004, 10:24 AM
David, that was my thought too, but I'm at work and can't remember if my existing rotor has a limiter or not.
I'm using a Crane ignition box for electronic limiting, so I'd like to get a non-limited rotor anyway. Hmmm.
Anyone know for sure if there are differences in how the two types fit the distributor shaft?
Thanks,
Colin
Old 03-25-2004, 11:36 AM
Original Owner
tsuter's Avatar
The cheap on is not limited. The more expensive one has the centrifugal limiter.
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 03-25-2004, 11:46 AM
Amac's Avatar
Colin,
I use the non rev-limiter.
The rev-limiter cost more.
I always ask for Turbo rotors
but I think it's the same as the
Carrera rotor.
"Never go faster than you can stop"
85 - 930 (750hp)
Norwood motec 3.5 twin turbo
Old 03-25-2004, 11:51 AM
Sounds like both rotor types will fit my distributor. I'll pick up the non-limited one.
One nice surprise is that the caps are dirt cheap compared to the Carrera caps. That's got to be a first for a 930 part.
Thanks guys!
Colin
Old 03-25-2004, 12:21 PM
Colin, I believe you can also use a non-limiting (later) SC rotor and cap. At least I have been for years. I use the MSD box to limit the revs
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 03-25-2004, 03:25 PM
Can you use the turbo rotor with centrifigul rev limiter on a 78SC?.
I would like a rev limiter for driver's ed events. The car has a motronic 3.2 conversion
Old 03-25-2004, 05:24 PM
Thanks Dean.
rds, that's an interesting looking engine. I guess the IC is set up to clear the stock decklid? Looks like a tight fit with the Carrera intake. I just installed a 930 intercooler on my 3.0 under a ducktail, but I'm still running the lower-profile 930 CIS manifolds.
Old 03-25-2004, 06:53 PM
Cowtown,
There is plenty of room even with Carrera manifolds,intercooler and stock deck lid. The trick is to mount the intercooler at the same sloping angle as the deck lid. I believe there is about 1/2 inch left.
Can anyone tell me if you can use the 930 rotor on a 78SC distributor?.
Old 03-25-2004, 07:15 PM
rds, take a look here:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_igniti_pg5.htm#item20
From the answers above, my 930 engine can use either of the turbo rotors. In addition, the 78-83 SC rotor in the link above has the same part number as the 86-89 930. Unless there's a flaw in my logic, you can use either of the turbo rotors, and the H-602-901-01 part is the one with the rev limiter.
Old 03-25-2004, 07:34 PM
Excellent!!Thank you.
Old 03-26-2004, 03:51 AM
beepbeep's Avatar
Motoronic has built-in rev limiter that cuts fuel. No need for limiting dizzy.
Thank you for your time,
Old 03-26-2004, 04:50 AM
Goran B. Dizzy
Thanks for the info. Very helpful
I like the piece of mind of redundant systems.
Old 03-26-2004, 07:21 AM
