which check valve should I get
I have a 1974 911 2.7. it has a hard starting problem and I need to order the correct fuel check valve. The 74 fuel pump is located in front of the drivers seat rear wheel and does not have a check valve like later models. Does anyone have a pelican part number of the items I my need? Thanks JK
bosch # 1 587 010 001. a capnut is also needed, N0110651.
