				Brake Pads:   will "A" caliper pads fit...
			will pads for "A" caliper fit an "S" caliper, and vice-versa?
				Bob
	71 911T track car project, highly bastardized. 79 Harley 74 916 clone (RIP -"...and he walked away")  |
			Bob,
			Yes to first question, and a note that most after market pads listed ... show the same replacement set for both caliper sets! No to second question, if you compare OEM Ate pads in the Porsche boxes! The true 'S' pads are 3 mm thicker, and hence won't fit if the rotor is new or still within spec!
	Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder'  |
			Thanks Warren - that's what I thought, but needed confirmation.   Do you happen thickness for either?
			Bob PS: I used to have a Barracuda, too - '64 273/4gear.
			The pad material thickness on an A pad is 10mm.
	84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others...  |
			Thanks 3.2 - appreciate the info!
			Each manufacturer ghas their own spec for those pads.  The factory spec is 10mm for the A and 13mm for the S.
					Current Pagid spec is 15mm for a sport pad and 19mm for a normal pad.
	Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes |  |
