79SC, trying to remove the blower in the smugglers hole in front. I have removed all the screws and disconnected the lines. Now what? It wiggles and feels like it is attached from below but I cannot figure out how, or do I remove the impossible to reconnect clips around the sides of the motor housing? Please provided some advice before I break something and must call the mortgage company for $ for parts!
Old Tee all 911s sold |
Blower removal requires you to remove the clips that hold the two-piece palstic housing together. Do a search here on this BBS.
--Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Pull the clips from the plastic housing,this will allow you to remove the top of the box with the motor giving you more wiggle room. And you will have access the 'guts' at the time. Just two bolts (at least my '87) one forward and one aft and out it will come. The lines will be very tight even after disconnecting the nuts, so wiggle and work on them.
'04 BMW R1100S BCR '01 Audi TT RS gone but not forgotten: '87 911 Carrera '59 356 Coupe '66 912 Speedster '99 996 Ducati |
This got me a few times - I kept on forgetting.
The trick is that there is an air return port which connects the smugglers box with the passenger compartment. There is a plastic duct thing that goes through the firewall and into the blower box which keeps you from lifting it up. To get it out - go into the passenger compartment, under the floorboard on the passeneger side. Unscrew the duct from the firewall and remove it. The whole kit and kaboodle will then lift right out of the smugglers box. hope hat helps.
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
Jasper is right. When I took mine out I did not have to seperate the the upper and lower halves of the box. It came out in one piece.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I second that opinion. Access to attach points in passenger compartment is needed for smooth removal.
I thank you. My wife thanks you too. She did not want to hear all those special words reserved for mechanical problems!
I'm in the process of ripping my A/C components out of the smugglers box, how does this come out?
PRO Motorsports
Unscrew the 4 perimeter screws, and pull it out. Easy as that.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Thanks Tyson, I guess it was in there tight. A couple hard yanks and it popped right out. Can I just start unbolting all of it in the smugglers box and rip it out?
I found (after pulling at the thing until I thought my arms were stretched) that you need to wiggle the evaporator toward the front of the car first to get it off the ducts that run to the cabin. Then you can pull it out. I didn't remove the top panel, guess it could have made it a little easier, but not sure.
There is a top duct that is held on with a hose clamp (the top duct in Par911's pic). This thing has a very tight fit and will need to be held out of the way with something (I wedged a screwdriver between the duct and the fitting). It's a bear to get out of there. Good luck. Gordo
Don "Gordo" Gordon '83 911SC Targa |
nice doggie
So far I've taken all the A/C off except the smugglers box stuff. I like the fan to bring fresh air into the cabin. What can go and still leave the fan to move the air? Is it a bear to get it back in there?
Jerry 78 SC hotrod 02 Mini Cooper S |
Thanks Gordo, Chris helped me out to fabricate a little plate to cover up the hole where the duct was in the passenger compartment. Thanks Chris. Here's the smugglers box without the A/C blower.
What the ....., bird seed?? Damn rodents!! You know, you try to be an animal lover, but you have to draw the line somewhere. ![]() So Marc, what works, mouse traps? Last edited by Par911; 03-29-2004 at 01:45 PM.. |
