Floor rebuild
I'm looking into buying a 1970 911T targa the only problem is that the bottom of the car seems to be in bad shape. The floor is perforated under the pedals, the inner rocker panels are in very bad shape, the body and mechanics seems OK. It needs an inspection to be able to go on the streets.
I would like to know is there a chance that the car would not be repairable if the chassis is in very bad shape or if I change the floor pans and rocker panels and spend a few thousand $ it can be repaired?? I think the price is low (8000$ Canadian, 6000$ us), I wouldn’t want to spend a few hundreds to bring it and have it inspected just to find out that I will never be able to put it on the street. Thanks, Philippe, hopping to be a Porsche owner very soon.
Philippe 1987 944S , the more I drive it the more I love it. |
On most 911s just about any rust is repairable now. The targas are harder to get right because their body rigidity is not quite as good. You can practically build one, though, with all the available repair panels. It all depends upon how much you want to spend. I can tell you that to repair a floor can be very expensive, if you pay someone else to do it. You either, better really want that car or have the skills to do it yourself. Otherwise you are probably better off waiting. For the money you will spend, you could have had a nicer one for less.
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis 1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916 |
