-   -   3.6 project is almost done! (http://forums.pelicanparts.com/porsche-911-technical-forum/155845-3-6-project-almost-done.html)
code7rpd 03-29-2004 12:31 PM
I took the car out for a drive yesterday even though the rear window hasn't been put in yet - I could'nt wait to drive it. I drove about half a mile and heard the sound of something fall off the car - looked in the rearview (side mirrors aren't hooked up yet either) and caught the sound of something shiny in the roadway - I pulled over, ran back, and found one of the exhaust tips wasn't tight enough and had come loose. So there I am in the middle of the street trying to pick up this very hot pipe. Finally got it, jumped back in, and drove to the gas station to fill it up. My initial driving impression was that the car runs beautifully - it really gets up and goes! I will have the mirrors and rear window done this week so I can drive it and then I can start on the interior. I also noticed that the back end of the car sits almost 1" higher than it did before - is the 993 motor alot lighter than the SC motor? I have attached a couple of pics - the pic of the exhaust shows one exhaust outlet - the other is still on my garage floor!
http://forums.pelicanparts.com/uploa...1080592281.jpg
code7rpd 03-29-2004 12:36 PM
another pichttp://forums.pelicanparts.com/uploa...1080592564.jpg
ZAMIRZ 03-29-2004 12:38 PM
OOOOOOOH, AAAAAAAAAAHHHHH, EEEEEEEEHHHH. I am DIGGIN the all black fan/shroud, very gangster.
Bill Verburg 03-29-2004 12:40 PM
The weight of the M64/05 as installed in your car is almost exactly the same as the old 3 liter w/ ac. If the car is sitting higher it's something else. They do have to be driven for a w bit to settle the suspension after being on a lift.
Looks great!, Is that Timmin's new header setup?
code7rpd 03-29-2004 12:46 PM
I'm having some trouble posting pics - I will try again later.
code7rpd 03-29-2004 12:48 PM
Yep - it's the Timmins exhaust set up - I was really impressed with the quality of workmanship and it sounds pretty good - not too quiet and not too loud.
MuffinMan 03-29-2004 01:05 PM
It looks great, I can't wait to hear your final driving impressions!
Bill Verburg 03-29-2004 01:11 PM
Hey Rob, how'd you make out at the dyno?
MuffinMan 03-29-2004 02:08 PM
The car actually did quite well, essentially what I expected. There were several stock cars (2 993s) to compare against, also. We video'd every run and I have the printouts of everyone's car. I'll post sometime tonight with links to the video and scans of the power curves. The bottom line is 253rwhp for my car.
Bill Verburg 03-29-2004 02:22 PM
Thats great! I can't wait to see the action and results. Wish I could have made it:(
GTC or here?
Moses 03-29-2004 03:59 PM
Manjit,
When can you drive it by? I need a closer look!
PS, My cars butt rode a little high for a day or two. It's temporary.
Jack Olsen 03-29-2004 04:31 PM
I wonder if the combination of a lighter-than-stock exhaust, missing rear windshield (35-40 lbs) and possibly lighter rear engine (if taking the power steering pump, heater blower and air box lowers what's considered the engine weight at all) could mean a slightly lighter rear end at the end of your swap?
Of course, the rear suspension settling back in will probably account for most of the change. How long had it been since those torsion bars were last fully unsprung?
pbs911 03-29-2004 05:10 PM
Very nice. I really like the exhaust. Any specs on that. I noitce a f/g rear. This could have added to the lightness raising the car if it was done at the same time as the motor.
surflvr911sc 03-29-2004 05:14 PM
Congrats on your conversion! I love the black fan and shroud; I’ve never seen anyone do that, very cool look.
I lost 100 lbs from my conversion, and that includes the oil cooling upgrades. I think the exhaust, heater blower, p/s pump, and replacing the huge old compressor w/ a newer one, or just getting rid it, really add up to a lot of weight savings.
The only other small contributing factor was the sound proofing under the carpet, but that wasn’t even close to 100 lbs worth and I did put in all new German wool.
Bill Verburg 03-29-2004 05:24 PM
A 993RS w/o ac, w/o heater motor, w/ a light flywheel w/ stock exhaust is 487#
A stock SC as installed w/ exhaust, steel flywheel, heater motor and ac is 485#
The difference in exhaust is only a few #s, the difference between a f/g and stock rear valance is ~19#
code7rpd 03-30-2004 06:26 AM
It looks like the front end has settled in and I would imagine the rear will also. I hope to have the windows in by the weekend and then I can drive it! The exhaust, for those interested, is from Timmin's - you can see it at www.instant-g.com under the Mcneil muffler set up. I wanted to thank everyone on the board for the help and advice - without this board I never would have attempted the swap. I also wanted to thank Mark (Moses) for letting me see your ride to compare what I was doing with the final result. Mark, I should have the windows in by the weekend so I can bring it by this weekend - let e know. Did you get the cats welded on?
Moses 03-30-2004 06:29 AM
Cats are in. Hope to see you and your car this weekend!
code7rpd 03-30-2004 06:52 AM
Cool - does it sound any different?
Kevin Stewart 03-30-2004 08:01 AM
looking good, Kevin
Moses 03-30-2004 09:01 AM
A little quieter. A little more low end torque.
