-   -   3.6 project is almost done! (http://forums.pelicanparts.com/porsche-911-technical-forum/155845-3-6-project-almost-done.html)
code7rpd 03-30-2004 10:00 AM
Cool - I'll give you a ring this weekend - maybe we can hook up on Sunday.
code7rpd 03-31-2004 06:55 PM
Just when I thought things were going great - I went to move the 911 and when I pushed in the clutch I initially felt some resistance and then the pedal just sunk to the floor. I heard something hit the ground and after some investigation I found that the cluth throw out arm which the clutch helper spring is attached to, broke in half - how does that happen!!!?? Would an incorreclty adjusted cluth caused that to happen? Could any damage have been done to the throwout bearing or pressure plate? Just when I thought I was getting ahead I get knocked two steps back! I attached a pic of the sheared off arm.http://forums.pelicanparts.com/uploa...1080788105.jpg
code7rpd 03-31-2004 06:56 PM
here is anotherhttp://forums.pelicanparts.com/uploa...1080788195.jpg
code7rpd 03-31-2004 06:58 PM
Here is another of the carhttp://forums.pelicanparts.com/uploa...1080788302.jpg
code7rpd 03-31-2004 06:59 PM
And one morehttp://forums.pelicanparts.com/uploa...1080788384.jpg
code7rpd 03-31-2004 07:03 PM
And one morehttp://forums.pelicanparts.com/uploa...1080788586.jpg
89turbocabmike 03-31-2004 09:15 PM
Code7rpd, it's tough to tell from the picture but from the coloring on the broken end it looks like it may have had a pre-existing fracture. Regardless, this sucks and I feel for you. I just put my motor back in a couple of weeks ago and I'm still nervous that something I did/didn't do is going to rear its head and require a re-drop! Your project is definitely going to pay for itself very quickly once everythings dialed in!
briansc 04-01-2004 05:39 AM
Sorry to hear about the broken arm on the clutch. Hopefully that is the only thing that is wrong.
Noticed the lift that is holding up the car - what is it and where did you buy it. Since I do a fair amount of work on my cars it looks like a very practical lift. Good luck and thanks.
code7rpd 04-01-2004 06:30 AM
The lift is from harbor freight. You can check this link for the post in the archives with all the information. Let me know if you need more information
http://forums.pelicanparts.com/showthread.php?s=&threadid=102162&highlight=code7r pd
code7rpd 04-01-2004 06:31 AM
Thanks guys. Hopefully I will get it dialed in this weekend - I'll let you guys know.
Dude76 04-01-2004 08:02 AM
The engine looks great, I hope I never run into you at a stop light all I'll get to see is the back end!
code7rpd 04-07-2004 02:39 PM
Good news all - I got the clutch lever taken care of and I am up and running. I drove to a window shop to have the front and rear windshields put back in correctly and since the front one wasn't seated correctly I didn't push the car really hard.....but.....the drive I did take was incredible..the car just gets up and moves!!! This weekend I will start the interior and hope to have it road ready really soon!!
