Can anyone recommend a good hi torque starter for Chevy swap?
I've got a Porsche '72 915 tranny from a 911 installed in my '81 DeLorean that has a Chevy V6 4.3 engine. (did ya get all that
) Well, the stock Porsche starter isn't quite enough to start the engine I guess because of the compression the engine has. It REALLY drags. (cold or hot) I had the starter checked out and they said everything was fine with the starter. I know there are quite a few of you guys who have dropped V8's into their cars and probably have had a similar problem or have modified your 911's. Any suggestions? Thanks in advance!
Team California
Yes, there are quite a few guys here who have dropped V-8s into their cars, help should be arriving soon. Don't hang up.
Denis |
I have 2 911s in the garage with V8s (what a coincidence). Hang on while I check what starter they have.... (I think I sourced them from JC Whitney if memory serves).. hang on...
'95 993 C4 Cabriolet Bunch of motorcycles |
Friend of Warren
Nono, I have been following your 911 engine into the Delorean since your first post. Glad to see you got the linkage problem worked out. You can get a hi-torque 911 starter that will fit your 915 tranny from our host, Pelican Parts. But before you buy a new starter, try pulling the spark plugs and see if the engine turns over. That 4.3 engine is not a high compression engine and a regular 911 starter should be able to turn it over. What kind of shape is your battery in?
Kurt V No more Porsches, but a revolving number of motorcycles. |
Team California
Never really thought about it, Kurt is right. Regular 911 starter should have plenty of power. Unless it's a diesel. It's not a diesel, is it?
Denis |
I'd just get a gear reduction starter from renegade or rod simpson....
pat --------------- 86 930 76 914 5.0 |
You guys are going to rip this poor man a new one before you're done, right? Anything Chevy attached to anything Porsche rankles the board.
FWIW, there are many starter and alt shops that build gear reduction starters based on a Japanese unit and a billet nose. You usually find these guys at auto swap meets, in the Drive magazine distributed at speed shops or on the Net. |
Team California
Nono, We like to kid around about Porschevs here, no big deal I hope.
Bottom line is that a stock 911 starter should turn that motor over w/ no problem. If not, I'd check the whole system.
Denis |
GAFB
Read carefully you tools. It's just a 915 trans into a DeLorean. No need to wake up the peanut gallery.
Nono, give a call to some of the 911 track/race preppers like TRG, Windward, KMR, etc. They've got the starters you're looking for all day long. Lighter and smaller than stock with gear reduction units.
Several BMWs |
Thanks for all the info guys!
Don't worry, I don't offend easily and I have thick skin...besides its in a DeLorean not a Porsche so I didn't mess up a real car Actually, the Porsche tranny is GREAT! Matched up with the Vortec 4.3, the car is ACTUALLY reliable now and I can enjoy it! The only problem is the severe starter drag. I put in a new battery so I'm sure its not a battery issue and I've got a HUGE ground wire going to it so I'm ok there too. I'm pretty positive its the starter though, because when I go to start it....it stops the starter....I release the key and hit it again (low compression stroke) and it fires right up. I thought the same thing...how could the 4.3 have that much compression I've read about a lot of people with V8's in their Porsches, but I never heard anything about needing a hi torque starter and as many as have been swapped, I would think it would have been an issue. That's why I thought the problem was in the current starter I have. Da well, hopefully a hi torque starter will solve my problem. Thanks again everyone! |
GAFB
Could you have possible set the spacing too tight and you are binding up on the ring gear?
Several BMWs |
Team California
The Chevy 4.3 Vortec motor is a massive improvement over the PRV motor that came in the car originally, I had a Volvo 260 w/ that same V-6 in it. What a toilet.
What trans did the DeLorean come with originally? P.S.: I was just goofing because of the "dropped V-8s in our Porsches" joke, no offense intended. (It was a joke, right?)
Denis |
"Read carefully you tools" - thats a bit harsh?
Is a delorian the car used in back to the future?? Rock ON!
Audi B7 S4 |
Administrator
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
I didn't think you are supposed to install a Chevy motor into a Porscha. It just ain't right.
Isn't their a more suitable firebird (perhaps one with the spit'n chicken on the hood) in your area to soup up instead?
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler Last edited by chuckw951; 03-31-2004 at 03:25 AM.. |
Maybe the high compression comes from the head having been skimmed...
Either way.. DeLoreans are cool. never see em over here.. Good luck rgds Doog
1971 2.2T 1992 Lancia Delta HF Integrale Evoluzione |
Unregistered
Thanks for all the info guys....however, the starter guy said that the starter is actually a hi torque starter. He said it had 4 of something (can't remember) so I have no idea where my problem may be. I don't think its the starter ring gear b/c the starter gear looks fine. Even though the battery is new, I guess I'm gonna swap it out and see if maybe its bad. Its got a 8 or 6 gauge ground wire going straight to the frame so I don't think its that. Da well
Friend of Warren
Before you swap it out, see if it spins over easily with the spark plugs out.
