first valve adjustment
I am very mechanically inclined. I can fix, literally, anything.
Is anyone in the NY Dutchess County area that is willing to walk me through my first valve adjustment on my newly purchased 87t with 47k? Thanks guys. Ken
Old 03-30-2004, 01:52 PM
go to barnes and noble and get "101 projects for your 911". that will walk you thru just fine. get the engine rebuild book too, "while you're in there." both by wayne dempsey.
206 637 4071
Old 03-30-2004, 02:06 PM
Make Bruins Great Again
Por_sha911's Avatar
I am not a mechanical wizard but have done my share of work on American cars years ago. I had someone "hold my hand" through my first valve adjustment. I think it is good to have someone with experience there so that you can know what the right "feel" is. You can't see your gap so its all about feel.
Also, call me crazy but I THINK that our hosts may just have a copy of the 101 Projects book for sale.
Joe
Old 03-30-2004, 03:27 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
Look in the tech articles here at Pelican. I used their article for my first valve adjustment on my SC and found it very helpful. Print it up and post near the car for grease free reference sheets. good luck.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 03-30-2004, 09:36 PM
Rocket Surgeon
Pettybird's Avatar
Send a message via AIM to Pettybird
Ditto on the online article. The 101 projects book is in my posession, but particular tasks like that one have far more detailed descriptions and pictures than what the book's size would allow. I'm all about the American cars, too, and this was the first "real" thing I've done to a Porsche alone. Definitely not the last... get the Bentley book, too.
-Doug
'89 951S, Velvet Red
Plymouth Superbird, Corporation Blue
Plymouth Superbird, Blue Fire Metallic
Old 03-30-2004, 09:46 PM
Chris Lovell's Avatar
There's great advice and instructions all over this forum and in Wayne's books. I also have a copy of the Bentley manual which is excellent for this and many other things for those mechanically inclined. Just one word of advice on your valve adjustment: Do not go in thinking you MUST adjust all the valves. Often you will find most of them are fine with just a couple needing set screw adjustment.
Good luck.
CWL
'88 Carrera Cab
Old 03-30-2004, 09:49 PM
all advice well taken. I will pick up the fore mentioned books. Thanks for the fyi on ....not necessarily needing to adjust all of the valves. I often try to fix an unbroke item first go around.
thanks again.
Old 03-31-2004, 06:37 AM
304065's Avatar
Where in dutchess county?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-31-2004, 06:46 AM
In Wappingers/ Hopewell. I work in Mt. Kisco.
Are you in the city?
Old 03-31-2004, 07:08 AM
Danskman's Avatar
It really is all about feel. I took a micrometer and set it at .004 and ran my guage through it to get a good indication what it should feel like. Good method if you're not sure. In my mind, it's a tricky job for three reasons;
1) working area for your feeler guage is difficult. I found pushing the edge of the guage against the valve stem and sliding it up to the gap area worked for me to find "the spot".
2) having a good "feel" for the proper gap. (very critical)
3) tightening the nut without turning the adjusting screw - even slightly, is challenging. Took me a few tries each time.
I did all mine 3x. Oh, and my engine was on a stand, not in the car.
Mike
'80 911SC Weissach Edition
'87 325is
'02 K1200RS
Old 03-31-2004, 09:04 AM
