-   -   targa questions - removing bits... (http://forums.pelicanparts.com/porsche-911-technical-forum/156090-targa-questions-removing-bits.html)
obrut 03-30-2004 07:40 PM
Some questions for the targa knowledgeable.
1. How is the rollover hoop attached to the body? bolts or welds?
(if its by bolts, then a simple bar between the mounting points - similar to a strut brace - should offer the same rigidity)
2. How is the windscreen frame attached to the body?
I'm trying to determine how reversible a speedster conversion would be.
3.2 CAB 03-31-2004 02:50 AM
The A pilars of the windshield frame are welded in place. A true Speedster windshield frame is shorter and at a slightly lower angle than a common 911. It seems to me that it would be a severe PITA to change one back once it has been "chopped"
ken_xman 03-31-2004 06:45 AM
the structural roll bar is welded. I currently have the black alum cover off mine, for refinishing.
Early_S_Man 03-31-2004 07:59 AM
There AREN'T any aluminum covers! Stainless prep will be a bit different than aluminum!
