targa questions - removing bits...
Some questions for the targa knowledgeable.
1. How is the rollover hoop attached to the body? bolts or welds?
(if its by bolts, then a simple bar between the mounting points - similar to a strut brace - should offer the same rigidity)
2. How is the windscreen frame attached to the body?
I'm trying to determine how reversible a speedster conversion would be.
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 03-30-2004, 07:40 PM
3.2 CAB's Avatar
The A pilars of the windshield frame are welded in place. A true Speedster windshield frame is shorter and at a slightly lower angle than a common 911. It seems to me that it would be a severe PITA to change one back once it has been "chopped"
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-31-2004, 02:50 AM
the structural roll bar is welded. I currently have the black alum cover off mine, for refinishing.
Old 03-31-2004, 06:45 AM
Early_S_Man's Avatar
Porsche Crest
There AREN'T any aluminum covers! Stainless prep will be a bit different than aluminum!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-31-2004, 07:59 AM
