electrical part of ignition switch
I am trying to replace the electrical portion of my ignition switch to hopefully cure my starting problem. How do I unplug the wires from the electrical switch under the dash? Does it just pull off, or are there tabs I need to release. Can I stick a screw driver inbetween and pry it apart? Any advice would help!
Old 04-28-2004, 08:51 AM
It is a tight fit but it is a friction fit. Try to wiggle it back and forth, but it will not twist. After you get that off, the electrical switch is held to the ignition housing by 2 small screws. Good luck
1986 911 Turbo
2002 VW Passat
2003 Dodge Caravan(family truckster)
5 custom built Harleys from past life
Old 04-28-2004, 02:27 PM
AirCooledExcellence's Avatar
Be careful if you decide to get the screwdriver in there, you don't wanna short anything out! (disconnect battery first maybe)
As safecracker says above it's a friction fit, but it's really tight up there!
Good luck!
Tim.
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD
1987 930 - SOLD
1983 911 SC Targa - SOLD
http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else
Old 04-28-2004, 02:41 PM
I will try again tonight. Thanks.
Old 04-28-2004, 02:59 PM
