Brake bleeding 4 piston calipers
What is the process for bleeding calipers with 2 bleeders per 4 piston caliper (944t calipers). I have new speed bleeders installed, can I bleed both at the same time, and should I still bleed in the order: right rear, left rear, right front, left front.
I bleed them in the order you have, one bleed screw at a time, beginning with the farthest outboard on the caliper.
Dave |
I'll second Dave's comments ;)
| All times are GMT -8. The time now is 08:46 AM. |
