Brake bleeding 4 piston calipers
What is the process for bleeding calipers with 2 bleeders per 4 piston caliper (944t calipers). I have new speed bleeders installed, can I bleed both at the same time, and should I still bleed in the order: right rear, left rear, right front, left front.
![]() 914 6 Turbo twinplug 3.12 87 924S Lexus SC400 Lexus LS400 |
I bleed them in the order you have, one bleed screw at a time, beginning with the farthest outboard on the caliper.
Dave |
I'll second Dave's comments
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
