Speedometer quit
Walked into the kitchen today and saw a hornet on my window.
Guess if they woke up it's time for the 911..so...had to make a run down the street and took the 73....Ahhh........felt good..... But, my speedo quit...Any ideas? Worked fine last year. |
Not Quite Banned
Speedo or Odo?
Thomas Owen 1972 911T 1972 911S |
odo been out for years.
Speedo just now out |
Home of the Whopper
Pull the speedo from the dash and see if the cable is connected. If it isn't, there's your problem. If it is connected, disconnect it. Go for a drive and see if the cable turns. If it does, your speedo is bad. If it doesn't, check the boss on the tranny to see if the cable is attached.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
