Harnesses from Racer Wholesale...... anyone
I need a pair of harnesses for the 78sc. Racer Wholesale has 6pt camlocks for $130.00 each. This seems a pretty darn good price.....has anyone used these harnesses?
http://www.racerwholesale.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=RW&Product_Code=GF-C5031&Category_Code=G-FORCE+Camlock+Harnesses
'02 6GT2 - Weekend toy
'04 6GT3 - Track weapon
'13 Cayenne GTS - Daily duty
'77 Yamaha RD 400 - Wheelie machine
Old 04-05-2004, 03:53 PM
Jess's Avatar
Craig,
Dave of Dart Auto used them in his car. I have driven his car in a four hour enduro race and they worked fine.
He is a local G-force dealer so he might even have a set you could check out here in Denver. Give him a call, 303-296-1188
Good luck,
Jess
Old 04-05-2004, 04:48 PM
Noel's Avatar
I used to have those belts in my old 300ZX track car, They work fine.
Noel
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 04-05-2004, 05:42 PM
Thanks Guys.
Jess, I'm on the road this week so calling Dave may be tough but I emailed to see what he can do regarding the harnesses. I'm also getting ready to mount a cooler up front so I'll see if he can assist there.
I'm trying to get it all together for "no times" at 2nd creek on the 18th but traveling 3 days plus the family obligations just doesn't leave enough time
Old 04-05-2004, 06:22 PM
jyl jyl is online now
jyl's Avatar
I have the G-Force camlock 5-points. Haven't used them all that much, but so far they are perfectly fine.
Make sure you specify exactly what you want in terms of pull-up, pull-down, length, etc. In my case, I correctly specified pull-down shoulder belts, but unfortunately also got pull-down lap belts which work but aren't ideal.
Not sure how you were planning to mount the harnesses, but FYI the G-Force eyebolts thread perfectly into the rear seat belt mounting points. I used the Brey-Krause adapters so I could keep my stock belts too.
Old 04-05-2004, 06:36 PM
