mjmoran's Avatar
Red face brake line whopps
Just checking and replaceing the rear rubber lines on my 89 Carrera and one of the solid brass lines from the flex to the caliper broke inside the nut...I do not see these in any part catalogs. This can not be an uncommon issue as my car has only 45K on her and I have never had her in water. I hate to see what the lines are like in my older cars...Any idea on where to get these and then to restrict this from happening again?
Michael
PCA-INWR
356 Reg.
Early S Reg.
R Gruppe PNW
Old 04-04-2004, 06:18 PM
one of gods prototypes
bell's Avatar
our host sells them, they're pretty cheap.........
i'll pull the page in the catalog
Brought to you by Carl's Jr.
Old 04-04-2004, 06:22 PM
lally911's Avatar
Pelican has them, I just got a whole set a few days ago. Try http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_brakes_pg8.htm#item29
Keith Lally
85 911 Blue Coupe - gone
84 911 Silver Coupe - gone
bell's Avatar
C-355-622-03 is the part number for the right line
C-355-621-03 for the left
on this page.....
Old 04-04-2004, 06:24 PM
The copper lines are a pain. The flare siezes to the line, and when you twist the flare to remove the line, it shears the it. Not sure when Porsche started using copper lines, though. Your older cars probably have steel, which will be fine. I helped a friend do some brake work on his 81 SC and his lines were steel.
Breaking the hard lines that go into the caliper sucks, but relatively cheap to fix. Breaking the hard lines on the other side of the flex line is an expensive thing if you want to keep the OEM copper lines (someone told me the lines would have to be ordered from Germany - $$$$). To avoid breaking lines when changing the flex line, what I do is cut the rubber line in half. Then hold the flare steady while twisting the rubber line off. The, after the brake fluid has drained, I use a small torch to heat up the flare and free the flare. I tried PB blaster, Liquid Wrench to no avail. Good luck.
Chris M
1985 911 Carrera w/ 3.6
Old 04-04-2004, 06:47 PM
mjmoran's Avatar
Thanks guys...any idea WHY Porsche went to the copper lines? Seems that most makes use steel lines. Would it possibly be an upgrade to replace the copper with steel all around?
Michael
PCA-INWR
356 Reg.
Early S Reg.
R Gruppe PNW
Old 04-05-2004, 08:16 AM
Irrationally exuberant
ChrisBennet's Avatar
Ever roll though an intersection because your steel brake lines rusted through? BTDT. Good thing there was nobody in front of me when the light changed!
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-05-2004, 08:23 AM
mjmoran's Avatar
Point, although it looks like my 993 lines, allroad lines, Ducati lines, wifes MB lines are all steel...have not checked the 356 or 67 yet...
Michael
PCA-INWR
356 Reg.
Early S Reg.
R Gruppe PNW
Old 04-05-2004, 08:42 AM
