SC rev limit rotor
Fellas,
I tried searching and after reading about 50 different threads with the words, SC, rev, limit and rotor I still haven't been able to locate the part number for an SC rev limiting rotor. About a month ago I had quite the scare when my throttle stuck open. Anyway, I was able to piece together that our host does not carry these (I suspect Euro part), and Vertex does, although I cannot find it on their site (way less user friendly than PP). Anyway, does anybody have a lead on these? Looking for one between 6000-7000 rpm... R/ Dustin |
You have to call Veterx, and they are the only ones that I could find that have it. I didn't have the part number, but told them the year of my car and what I wanted and they knew exactly what I was after. For my car, I got the 6800 rpm one, and it works very nicely. I'll look for a part number on it in a little while if you can wait.
Sorry, I was not able to get a part number. Actually I wasn't able to get the damn rotor off of my dizzy, and didn't want to break the rotor doing so. Did you have any luck finding the part? There is some info in this recent thread, where I posted pictures of my rev-limiting rotor while I was trying to get it off.
Thanks for the try...I'll vertex and order one...
Still have the box from when I replaced mine...believe it's a 6800 RPM model. Part # is 930.602.901.02. Not sure of the etiquette if our host doesn't carry the part, but I got in touch with a Porsche dealer in Charlotte that had a connection.
I do think it would be cool though if Wayne would carry some of the Euro parts...I see enough Euros in the posts that a few of the common parts would really help us out. |
Wayne lists that number as a special order part..are you sure he can't get it?
I got one from TRE. Its a 930 part I think.
As for the Euro rotors, the last time I checked, there was only one of them available in the United States through Porsche. However, we can probably special order them from Germany, but that would (A) take a while and (B) perhaps not be very cost effective. Is there really a profound interest in these? I will try to find out as many details as I can. |
Lots of mid-year cars with SC US 3.0 engines and no rev limiter. Might be a market. Any that go higher than 6800?
--.02 is the Turbo rotor ...
930.602.901.01 is the ROW SC rotor, 7000 rpm per the spec book! |
Thanks Warren!
The rotor that was on my car was a Bosch p/n 1234 382 240 set @ 6800 rpms. Anyone have a cross reference between Bosch and Porsche part numbers?
What does it take to install the rev limiter? Is it just a matter of swapping out the rotor?
Eugene
Warren shows the .02 as the tubo rotor, your catalog shows the .01--could you check the numbers? Didn't the early RS have a much higher redline? What about those rotors? |
Mike-
Yes, it's just a matter of swapping rotors. The rev-limiting rotor is a bit larger and (obviously) has more small parts. |
For non-turbos (not sure about the turbos), the distributor changed size in '78 I think. I'm sure someone will correct me with all the specific sizes, years, dates..... I purchased a rev limiting rotor locally for a '76S and it was too small for my SC. The car still ran, but not very well because the spark had to jump a few extra mm's. The one pictured in the Pelican catalogue that Warren listed looks like the one I bought for a 76S. I'm probably wrong about something there, but worth mentioning.
Here is mine for reference: http://forums.pelicanparts.com/uploa...1081298101.jpg |
.02 is the ROW SC rotor that you guys are looking for and is rather scarce in America. I'm still researching its availability. Rev-limiting rotors for early 911s (although readily available in the States) will not fit SC or 930 distributors. |
Here is the '72 - '77 rev-limiting rotor ... smaller OD!
http://www.pelicanparts.com/techarti...just_pic16.jpg |
| All times are GMT -8. The time now is 12:44 PM. |
