-   -   Thermal Reactors (http://forums.pelicanparts.com/porsche-911-technical-forum/157328-thermal-reactors.html)
911mike 04-07-2004 09:06 AM
Thermal Reactors
Has anyone tried wrapping header wrap around the thermals to keep the heat away from the engine? This stuff supposedly works on race cars but I don't know what effect it'll have on a 911 engine. Any thoughts?
CHILI 04-07-2004 09:13 AM
How about just going with 3 in 1's? MUCH, MUCH, MUCH cooler and better for your car. I have a set in my garage if you're interested. I'm running SSI's now.
911mike 04-07-2004 09:17 AM
I also have the 3 into 1's in my garage. Thanks for the offer. I need to pass smog soon.
JP911 04-07-2004 09:19 AM
What if you just get the engine really hot right before you take it to get tested? Or are you more concerned about the visual check?
CHILI 04-07-2004 09:20 AM
Have you tried passing smog with the 3 in 1's on? What year is the car? If it's got thermals, it can't be too far from not needing smog. Wohoo!
911mike 04-07-2004 09:28 AM
Last time I took the ol '76 in for smog, after getting the car nice and hot, it sat for 2 hours in the parking lot before he got to it! Passed with flying colors even though it didn't get on the treadmill.
CHILI 04-07-2004 09:42 AM
Exactly! Well, at least this will be the last time (since it's every other year). Assuming they don't repeal the law. Not sure if you've heard about the issue. There was a post about it a while ago. I love not having to worry about it. Plus my reg is only something like $70. Nice!
vash 04-07-2004 11:20 AM
one more smog test! i think the thermal wrap stuff was made for the two stroke motor crowd. it made the exhaust hotter, which in turn makes the spent gases "dump" into the bladder-like pipe easier. some thermodymamic theory stuff, that i almost failed in college. on your reactors, it would cook! good luck on your LAST smog!
911mike 04-07-2004 11:34 AM
Thanks! I can't wait to get this over with.
