-   -   What's this part, and how bad is it? (http://forums.pelicanparts.com/porsche-911-technical-forum/157570-whats-part-how-bad.html)
Par911 04-08-2004 04:36 PM
I know it is something electrical, but what is it exactly? I have been searching, but I'm unable to find a diagram that explains what it is. I noticed that the yellow fitting for this part is cracked, is this something that needs attention immediately? http://forums.pelicanparts.com/uploa...1081466870.jpg
ischmitz 04-08-2004 04:36 PM
Cruise control actuator. And it should work fine even like that. It's a vaccum can that based on the cruise control's brain pulls open the throttle. The cable should run over to the throttle body. I wouldn't worry about it.
Ingo
Par911 04-08-2004 04:39 PM
Cool, thanks Ingo!! I guess I don't even have to worry about it since the cruise control is disconnected.
ischmitz 04-08-2004 04:42 PM
There you go. Yank it out and save a couple of ounces of weight.... :)
Par911 04-08-2004 04:47 PM
Ingo, the cable does run up to the throttle body, but is disconnected from it. Can I remove the actuator? Will it mess anything else up? Everyone else I talk to tells me to leave it alone but I'm thinking that's a few pounds that could be shed. Besides who wants cruise control on a 911 :D?
Par911 04-08-2004 04:49 PM
Whoa, you answered my next question before I even posted it. Are you into telepathy? ;) Thank you Ingo.
ischmitz 04-08-2004 04:53 PM
Well,
make sure that you block the vacuum hoses that go to it. They will also come somewhere from the intake plenum. You don't want to end up with a big vacuum leak.
