-   -   what is t h a t ????? (http://forums.pelicanparts.com/porsche-911-technical-forum/157910-what-t-h-t.html)
capuni 04-11-2004 03:17 AM
http://forums.pelicanparts.com/uploa...1081678296.jpg
i bought it from e bay,it should be from a 911. but what year is that?
how many degrees does the temp gauge messures? and what senders do i have to put?
if i'll put a universal vdo oil pressure sender(for 150 psi),will it work?
please answer me,it will help me a lot
thanks
palle7688 04-11-2004 03:47 AM
I don't remember, I'll see if i can look it up somewhere
Joe Bob 04-11-2004 05:28 AM
Look on the back....most have a date on them.
MovOvr1 04-11-2004 07:52 AM
Looks like it might be from a european car with the temp numbers being in Celcius(??) Don't know though,.....just a thought.
Brian
79 930
MAS 04-11-2004 08:28 AM
"Looks like it might be from a european car with the temp numbers being in Celcius..."
Not necessarily... my (Canadian) car has the temp markings in Celcius. This gauge has no numbers at all.
-MAS
Joe Bob 04-11-2004 08:31 AM
A lot of those gauges have the oil temp along the side under the lip....check it, might be surprised. My SC has them and I take a look every once in a while to jog my memory. Kinda dumb to put them there....
carmad 04-11-2004 10:32 AM
Looks like its from a 72-73 era car from the pictures in Peter Morgans book.
lateapex911 04-11-2004 10:43 AM
Brian
79 930
Maybe I'm really confused, but it looks like the whole guage is dedicated to oil, and the numbers on the right are pressure units. The actual numbers would correlate well to PSI, not "Druck" (bar) units as in Europe, so I'm betting it's for the American market.
The left side, for temps, is reminding me of that "no numbers" era in the late sixties/early seventies. The guages coloring look appropriate to that era as well. Perhaps this guage was used in the "starter 911", the 912, where Porsche engineers may have assumed that the owners would be fine with a red line and no numerical markings.
Just a WAG, though!
pjv911 04-11-2004 10:46 AM
Why all the guessing ? the date is on the back. Also if it has mounting studs its a 68-69 gauge . If theres no studs its a 1970 -73` .
Kurt Williams
techweenie 04-11-2004 10:51 AM
Could be a 916 gauge.
It's not anything you'd find in a U.S. 72/73 911.
pjv911 04-11-2004 11:07 AM
Heres a 1969 911S gauge .
http://forums.pelicanparts.com/uploa...1081706423.jpg
1974 911
http://forums.pelicanparts.com/uploa...1081706475.jpg
svandamme 04-11-2004 11:22 AM
don't think there was any green on 911 gauges in 72/73
at least not on mine
also , Euro gauges, don't use psi
they have temp on the left going up to 150 C and pressure on the right going 0-2-4-6-8-10
techweenie 04-11-2004 11:27 AM
It's the high range of the PSI side that has me most puzzled.
pjv911 04-11-2004 11:28 AM
I dont think thats actually green. Likely just the picture quality. I have over 300 or more early 911 gauges. And have seen that gauge in the boxes before. Its not rare or valuable. I just cant put a finger on the exact application. As with all VDO/Porsche gauges the part # is under the glass at the very top. That would be an easy way to end this confusion.
Kurt Williams
c_fahlen 04-11-2004 11:36 AM
I doubt it's a 72/73 gauge.... According to "A restorers guide to authencity" by Dr. B. Johnsson no cars from 64 - 73 have a gauge with no numbers on the temprature scale...
svandamme 04-11-2004 11:37 AM
dunno kurt, but the white looks white to me, so if the white's there, then that looks distinctly like green.
if the pic would have been bad quality , then my guess would be that either everything would look greenish
pjv911 04-11-2004 11:47 AM
Stijn , you do have a point.
Kurt Williams
nostatic 04-11-2004 11:48 AM
only the temp bars look green (as opposed to the numbers). '67 and earlier were green guages, but the numbers and bars were green.
There is a picture of a RHD '73 in Morgan's book that sorta looks like this one (numbers the same on the press side, no numbers on the temp side)...except the one in the '73 has a different looking bar setup on the temp side.
svandamme 04-11-2004 11:48 AM
Kurt Williams
doesn't happen often , i'll savour this moment :D:D
pjv911 04-11-2004 11:57 AM
Think that one is a mystery ? Ever seen one of these units which have a idiot light at the top of the oil temp bar ? I will let you guys ponder on this one before I tell you. Or does somebody know ?
Kurt Williams
http://forums.pelicanparts.com/uploa...1081709613.jpg
Here`s a pic of the motor from the same application. See any clues ?
http://forums.pelicanparts.com/uploa...1081709856.jpg
