Mysterious clunk
I get a mysterious clunk noise like the car is bottoming out when I hit a pot hole on the right hand side. The left side is fine. Any suggestions on what it could be. I just ordered new shocks today. Hopefully that is it but wondering what else could cause it.
Thanks,
Old 04-12-2004, 01:55 PM
Friend of Warren
Front or rear. Loose shock would be the most obvious problem.
Kurt V
Old 04-12-2004, 01:57 PM
curlesw's Avatar
If/when you find out let me know. I have been told my "clunking noise" is coming from bushing...but I have not had a chance to replace it.
v/r
Wayne C.
Old 04-12-2004, 02:13 PM
Steve W's Avatar
Worn a-arm bushings - causes torsion bar to clunk against the tube housing it.
Old 04-12-2004, 02:19 PM
Could also be a torn rear sway bar mount - a very common problem.
Bill
Old 04-12-2004, 02:23 PM
As I am new to porsche......it might not be applicable.
For strange clunking inthe nose of many cars turn out to be a strut bearing plate in the top mount of the strut tower.
If everything else looks ok.................
Old 04-12-2004, 02:29 PM
oneblueyedog's Avatar
Check the ball joints on the a-arms.
78SC coupe, Silver Metallic
Old 04-12-2004, 02:57 PM
goat's Avatar
I had a clunking sound for a while. It was solved when I reinstalled the rear sway bar which the previous owner installed upside down!!!
Tim.
1988 911 Carrera. Silver.
1973 914 Metalic Blue.
2012 Cayenne S
Old 04-12-2004, 04:10 PM
dickster's Avatar
i had what i thought was a similar sound coming from the rear - it was one of the front strut inserts come loose from when i installed them a year a so ago.
Rich
'86 coupe
"there you are"
Old 04-12-2004, 11:13 PM
