Mysterious clunk
I get a mysterious clunk noise like the car is bottoming out when I hit a pot hole on the right hand side. The left side is fine. Any suggestions on what it could be. I just ordered new shocks today. Hopefully that is it but wondering what else could cause it.
Thanks, David |
Friend of Warren
Front or rear. Loose shock would be the most obvious problem.
Kurt V No more Porsches, but a revolving number of motorcycles. |
If/when you find out let me know. I have been told my "clunking noise" is coming from bushing...but I have not had a chance to replace it.
v/r Wayne C. |
Worn a-arm bushings - causes torsion bar to clunk against the tube housing it.
Could also be a torn rear sway bar mount - a very common problem.
Bill |
As I am new to porsche......it might not be applicable.
For strange clunking inthe nose of many cars turn out to be a strut bearing plate in the top mount of the strut tower. If everything else looks ok................. |
Check the ball joints on the a-arms.
78SC coupe, Silver Metallic |
I had a clunking sound for a while. It was solved when I reinstalled the rear sway bar which the previous owner installed upside down!!!
Tim. 1988 911 Carrera. Silver. 1973 914 Metalic Blue. 2012 Cayenne S |
i had what i thought was a similar sound coming from the rear - it was one of the front strut inserts come loose from when i installed them a year a so ago.
Rich ![]() '86 coupe "there you are" |
